Unable to reprogram links to PLM
This topic is closed.
    I just replaced an old PLM (2414UH)with a new one (2414U) and ran the module "Program replacement/swapped interface." It ran with very few glitches, but I can't seem to correct those glitches. On the main config page it tells me:
    The following are unregistered Insteon addresses found in the network.
    18.B8.6C found in Garage Fluorescents
    18.B8.6C found in Kitchen Sink
    18.B8.6C found in Landing Holiday Lights
    18.B8.6C found in Laundry Room Fluorescents
    18.B8.6C found in Living Room Christmas Tree
    18.B8.6C found in Living Room Nightmare Lamp
    18.B8.6C found in Living Room RemoteLinc
    18.B8.6C found in Living Room Salt Lamp
    18.B8.6C found in Master Bedroom KeyPadLinc
    18.B8.6C found in Master Bedroom Momchu's Nightstand Lamp
    18.B8.6C found in Master Bedroom Popchu's Nighstand Lamp
    18.B8.6C found in Office Motion Sensor
    I click on the link to each device, let's say, Kitchen Sink, and I see:
    Link #2 Switch/Load is controlled by Unregistered Device Group 17 (18.B8.6C) - Command: On
    18.B8.6C is the new PLM. So...what do I click to get this to recognize? I tried "Read Device Links and Settings" and that doesn't clear it up.
    Jim Speiser
    38-year veteran of Home Automation
    Still don't know squat
    have you tried reprograming the groups from the plugin?
    so just be clear to others, you have migrated from 2413uh to a 2413u
    Mark
    HS3 Pro 4.2.19.5
      Not familiar with "reprogramming the groups from the plugin." And yes, without pulling the damned thing out of the wall again to look, I'm pretty sure that's what I did.
      Jim Speiser
        do you have groups defined in the plugin? Manage Groups tab
        if so check for one with ID 17 and use the reprogram button
        Mark
        HS3 Pro 4.2.19.5
          I do have groups, but none have ID 17.
          Jim Speiser
