I have a single motion sensor that is pre-configured (in the Insteon Plug-in) for having a "heartbeat" status. Reading through here, I get the impression that "heartbeat" is an IOLinc status. Does it also apply to Motion Sensors? Only a certain release of Motion Sensors? Or is it not supposed to be there at all?
Motion Sensor Heartbeat?
This topic is closed.
a MS with fw 44+ does have a heartbeat device. its supported in version 3.0.5.61 or later
the heartbeat provides status and also an indicator that the unit is still online.
you can setup a trigger for notification if you haven't received a heartbeat msg in a day or so.Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Posta MS with fw 44+ does have a heartbeat device. its supported in version 3.0.5.61 or later
Originally posted by claude View PostWhere can I find the details on this heartbeat?Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postyou just found it Smarthome doesn't document these features for the general public.- At what frequency does the MS send out a heartbeat?
- Does it trip the HS device On then back to Off?
- Does it operate regardless of other settings, for example when 'night only' is set?
every 24 hrs, I believe.
Yes
YesMark
HS3 Pro 4.2.19.5
add RecreateDevice=1 to the [device x] section of the MS and then restart the plugin or homeseer. This will rebuild just that one device. should fix the graphics/status
if it doesn't delete the device from the plugin, and re-registerMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postadd RecreateDevice=1 to the [device x] section of the MS and then restart the plugin or homeseer. This will rebuild just that one device. should fix the graphics/status
Let me know what you think of the heartbeat function when you have a chance.Mark
HS3 Pro 4.2.19.5
Originally posted by claude View PostSo then here go the questions:- At what frequency does the MS send out a heartbeat?
Originally posted by mnsandler View PostLet me know what you think of the heartbeat function when you have a chance.
Here's the event:
Originally posted by claude View PostI have an event to write to the log when the MS heartbeat signals. I see "Last Ran: Today 2:13:50 AM" against that event, but there's no entry in the log. I also have an event that sends me an email if no heartbeat in the last 48 hours and again no email sent, so the heartbeat must have signaled. What am I not seing here?
Here's the event:Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postare you seeing the insteon heartbeat msg at all?
To clarify...
I see no heartbeat in the log.
I have these events:- Check if 'heartbeat' device changes and becomes On: event has never triggered
- Check if 'heartbeat' device transmits an On command: event has never triggered
- Check if 'heartbeat' device has been Off for at least 2 days: hasn't been 2 days yet since I created this event
