Acccess points don't get linked to anything; they just forward msgs. You can register them if you want but the only status you will get is whether they are online or offline which is based on a periodic ping.
Mark
HS3 Pro 3.0.0.534 Hardware: Insteon Serial PLM | AD2USB for Vista Alarm | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting Platform: HP h8-1360t, Windows Server 2012 R2, i7-3.4GHz, 16GB memory
At one time I think you explained to me how to get the access points to indicate if they are commutating with each other. I'm wondering if you can explain how to do that once again ???
Lastly does it matter that one is a range extender ??
the range extender and access point are basically the same device; i think Inteon rebranded the access point to range extender. so you can use one of each
are you trying to connect a second structure (like a shed/barn/garage) to the main house?
Mark
