I'm stuck here..... I have created an event to turn off several lights, by double tapping off a switch.
Note: if i manuall fire the event by clicking on the blue run arrow this works... However no matter which switch I pick as the selected device, double tapping OFF will not run the event it only turns off the device associated with that switch.
I could use some guidance..
If you have other examples of how you would do this I would also appreciate that.... Thanks
Devoir
Devoir
