Insteon mini remote (8 button)
  • Insteon mini remote (8 button)
    I have a USB dongle for the insteon connection, and I am trying to set up an 8 button mini remote. It does add to the insteon plugin successfully, but only as a 4 button remote. I have looked through the insteon help files and tried to set it as an 8 button toggle, but for some reason even deleting and re-adding to HS does not fix this.
    Does anyone have experience with this combination, or maybe some tips to fix this? It seems that buttons A-D are registered as 1-4, but the E-H buttons do not do anything.
    Thanks in advance!
    what plugin version are you running?
    you might try a factor reset on the remote.
    Mark
    HS3 Pro 3.0.0.534
      I just realized I posted this in the wrong forum. I am using the HS insteon plugin. My apologies!
      I will attempt resetting the remote, however, and see if that helps.
      Can this thread be moved to the HS insteon forum?
        I have found that the 8-button remote is not supported by this plugin. After trying the paid Insteon plugin, it works as expected.
          I will update the plugin comparison chart on the following thread
          https://forums.homeseer.com/showthread.php?t=184037
          thanks for posting your findings.
          Mark
          HS3 Pro 3.0.0.534
