So I purchased a couple dual control outlets for Christmas and am getting around to integrate them into my HS system. Using the HS Insteon plugin, I don't see a way to control the 2 separate outlets, like the device allows. Is there a way to set this up so I can control both outlets separately?
Dual control outlets
Originally posted by joegr View PostI can only say that the dual outlets work correctly with the paid Insteon plugin.
Go to Plugins - Insteon - Configuration - Manage Devices - Add new Insteon Device
Key in the six character ID of the dual outlet link
Name it as desired
Select Confirm Add
When it is done, you will have two new devices, one for the top outlet and one for the bottom one.
Note that you will have to re add all of your Insteon devices this way.
- 1 like
Originally posted by joegr View PostGo to Plugins - Insteon - Configuration - Manage Devices - Add new Insteon Device
Name it as desired
Select Confirm Add
You should probably move the discussion on that to here: https://forums.homeseer.com/forum/li...teon-mnsandler
You'll get great support.
