I'm moving this to another section of the forum
Enable Insteon Interface on startup?
I use the disable Insteon interface action when the power fails (since the PC continues running for up to an hour on a UPS). I have a virtual device that I set to keep track of if the Insteon interface is enabled or disabled.
If power comes back before the PC shuts down, I have an event the uses the enable Insteon interface action to turn it back on. If the PC shuts down before power comes back, the same event calls the enable Insteon action. It is triggered by the AC power being on for at least two minutes while the virtual device indicating that the Insteon interface is off is off.
