New HS3 Insteon Plug-in Beta
    Our new insteon plug-in is now in beta. To test, navigate to the updater in HS3 and open the beta section at the very bottom of the plug-in list.
    The plug-in has been tested with the following products:
    2413U PLM
    2843-222 TriggerLinc Door Sensor
    2443 Access Point
    2342-232 RemoteLinc 2
    2444A3WH RemoteLinc 2
    2450 I/O Linc
    2457D2 LampLinc
    2466DW ToggleLinc
    2466SW ToggleLinc
    2473SWH OutletLinc
    2477D SwitchLinc
    2477S SwitchLinc
    2334-232 KeypadLinc
    2487W KeypadLinc
    2842-222 SkyLinc motion sensor
    2456S3 ApplianceLinc
    Learn About HomeSeer
    interesting...I didnt think HomeSeer was going to play in this market any longer.
    Will this be a licensed plug-in?
    Is this going to have limited support of devices in comparison to Marks plug in?
    HS Install Date: Feb. 16, 2007
    HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
    WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
      Yes, this will be a licensed plug-in and yes, it will be a bit simpler and more limited than Mark's plug-in. The devices listed above have been tested with it and should work just fine.
        Any plans on supporting the insteon Thermostat?
          depends on the demand. we're considering it.
            What about support for the Hub interface?
              Is there any way to get the 8 button keypadlink to work? The 6 button works perfectly, seems like 2 more buttons should be easy.
              Codemonkey
              HomeSeer Version: HS3 Pro Edition
              Operating System: Microsoft Windows 10 Pro
              Processor Type and Speed: i7 - 3.26 GHz
              Total Physical Memory: 16Gig
              Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
                2477D Switchlink Dimmer
                This works fine in Homeseer but HSTouch sliders will not control it. They will report the status interestingly enough so if I set it in Homeseer or physically the slider changes. When I move the slider though nothing happens. If I set a button for full on or full off that works. I wasn't sure if this should go here or the HSTouch area.
                  Anything on the HSTouch sliders? also will it be possible to set custom ramp rates per command?
                    X-10
                    Will this support X-10?
                    Terry
                      Re: New HS3 Insteon Plug-in Beta
                      Custom ramp rates would be sweet
                      Sent from my htc Inspire 4G using Tapatalk
                      HSPro: 3.0.0.194
                      PL: Insteon PLM 3.0.5.20,Insteon Thermostat 3.0.1.1 , UltraM1G, RainRelay8, UltraECM3, UltraPioneerAVR3, BLBackup, weatherXML, Jon00 Network & PC Monitor
                      HW : Win 7 64bit, Intel i7-2600, 16 GB DDR3 Ram, 60 Plus Insteon Dual Band Devices, Rain8 Pro2, Elk M1 Gold, Brueltech GreenEye.
                        Any update?
                          bump
                            +1 for Insteon thermostat support, also please support the EZFlora, since the plugin dev has no plans to support a Linux version: http://board.homeseer.com/showpost.p...2&postcount=11
                            I must say that I've very disappointed in the lack of proper HS support for Insteon. I know you guys have a massive chubby for zwave, and that's fine, but after buying the pro version, and then learning that I still have to by 3rd party plugins for a major lighting & control technology, and then learning that it's pointless because even with that, I still can't run everything because my OS isn't supported by one of the plugins. My house has 5 Macs, 5 Linux boxes (several more more if you count all the RPi scattered about) and no Windows boxes. Please consider giving us proper Insteon support or bundle the 3rd party Insteon stuff with Pro.
                            I very much want to use HS, but it's sat on a shelf (figuratively) for over a year while I wait for support that may never come.
                            Terry
                              Terry
                              +1 for all of this. I'd really like to see this plugin be more useful.
