I added about 6 Insteon devices and none of them show up on the device status screen. I tried moving them to different rooms/floors. They just don't show up.
Devices don't show up on Device Status
you need to select show all from each of the filter lists.Mark
HS3 Pro 3.0.0.534
On the status page will not display root devices and right now the Insteon devices are set as root devices. We will get this fixed.
Originally posted by chadg View PostI added about 6 Insteon devices and none of them show up on the device status screen. I tried moving them to different rooms/floors. They just don't show up.
This should be fixed now, update to ver 1.0.0.5 of the plugin. Note that the previous version was mislabeled in the updater as 3.0.0.4 but was really 1.0.0.4.
I'm having the same issue. I have added the 1.0.0.9 Insteon plugin and is showing the powerlink in the config. Then I add a devices but when I go over to Device Manager it does not show the PowerLink or the device I just added. I have everything checked in the filters. How can I get this to work?
