Togglelinc cuts on but not off
  • Togglelinc cuts on but not off
    I have a togglelinc that can be turned off and on locally and on from homeseer but it does not respond to off commands. Here's what comes up in the log:
    Sep-29 5:43:31 PM HSInsteon ERROR Command Off timed out for device 20.50.80
    Sep-29 5:43:31 PM HSInsteon DEBUG ERROR: Device 20.50.80 Command Off timed out
    Sep-29 5:43:27 PM HSInsteon DEBUG PLM: 02 62 20 50 80 0F 13 00 06 ACK
    Sep-29 5:43:27 PM HSInsteon DEBUG PROCESSOR: Echo '62 20 50 80 0F 13 00' matched
    Sep-29 5:43:27 PM HSInsteon DEBUG RX: 02 62 20 50 80 0F 13 00 06
    Sep-29 5:43:26 PM HSInsteon DEBUG TX: 02 62 20 50 80 0F 13 00
    Sep-29 5:43:26 PM HSInsteon DEBUG Device 20.50.80 Command(command:Off, value:00)
    Sep-29 5:43:26 PM HSInsteon DEBUG WARNING: Device 20.50.80 Command Off timed out, retry 3 of 3...
    Sep-29 5:43:25 PM Kinect INFO Posture Detected: HandsJoined
    Sep-29 5:43:21 PM HSInsteon DEBUG PLM: 02 62 20 50 80 0F 13 00 06 ACK
    Sep-29 5:43:21 PM HSInsteon DEBUG PROCESSOR: Echo '62 20 50 80 0F 13 00' matched
    Sep-29 5:43:21 PM HSInsteon DEBUG RX: 02 62 20 50 80 0F 13 00 06
    Sep-29 5:43:20 PM HSInsteon DEBUG TX: 02 62 20 50 80 0F 13 00
    Sep-29 5:43:20 PM HSInsteon DEBUG Device 20.50.80 Command(command:Off, value:00)
    Sep-29 5:43:20 PM HSInsteon DEBUG WARNING: Device 20.50.80 Command Off timed out, retry 2 of 3...
    Sep-29 5:43:16 PM HSInsteon DEBUG PLM: 02 62 20 50 80 0F 13 00 06 ACK
    Sep-29 5:43:16 PM HSInsteon DEBUG PROCESSOR: Echo '62 20 50 80 0F 13 00' matched
    Sep-29 5:43:16 PM HSInsteon DEBUG RX: 02 62 20 50 80 0F 13 00 06
    Sep-29 5:43:15 PM HSInsteon DEBUG TX: 02 62 20 50 80 0F 13 00
    Sep-29 5:43:15 PM HSInsteon DEBUG Device 20.50.80 Command(command:Off, value:00)
    Sep-29 5:43:15 PM HSInsteon DEBUG WARNING: Device 20.50.80 Command Off timed out, retry 1 of 3...
    Sep-29 5:43:11 PM HSInsteon DEBUG PLM: 02 62 20 50 80 0F 13 00 06 ACK
    Sep-29 5:43:11 PM HSInsteon DEBUG PROCESSOR: Echo '62 20 50 80 0F 13 00' matched
    Sep-29 5:43:11 PM HSInsteon DEBUG RX: 02 62 20 50 80 0F 13 00 06
    Sep-29 5:43:10 PM HSInsteon DEBUG TX: 02 62 20 50 80 0F 13 00
    Sep-29 5:43:10 PM HSInsteon DEBUG Device 20.50.80 Command(command:Off, value:00)
    Sep-29 5:43:10 PM Device Control
    Anyone? This is driving me nuts!
      What load is this switching on and off?
      What happens if you disconnect the load? Does the log then show that the off command is acknowledged?
      (I had a noisy florescent fixture cause a similar issue once.)
        It is fluorescent screw I bulbs I'll try this
          I took out one of the CFL's and the issue went away think it's a bad bulb?
            Bad or cheaply made. I haven't had any trouble (yet) with LED bulbs. Ones that give out the equivalent of 60W are around $10 now. You might try one. Make sure it is a dimming type.
