2413u problems - Solved!
  • 2413u problems - Solved!
    I have a basic insteon set up going and wanted to change over to homeseer. I have the Hometroller zee. I got it this past Christmas. I purchased a 2413u as a controller and plugged it in. Now when I go in to hsinsteon plug in configuration I get: Error: Cannot find controller. I am not sure how to proceed. I have set the com to usb1 and usb2 and neither worked.
    Rkshack
    Here is what the log says:
    Jun-05 7:49:30 PM Plug-In Finished initializing plug-in HSInsteon
    Jun-05 7:49:30 PM HSInsteon ERROR Cannot connect to port: /dev/ttyUSB0
    I think by turning off x-10 plug in and then turning on insteon I got it up and running. I can control devices. If I turn x-10 on with cm11a compatability it breaks the insteon and it will stop working. I can get insteon working again by turning off x-10 and restarting insteon. If I try to start x-10 with the ti103/203 mode then it will not get past starting.
    Any one can help me?
    Rkshack
    partially solved
    I removed the zstick and now hinsteon can find the 2413u device and it works well. If I reinstall the zstick everything breaks. Any suggestions.
      solved
      Ok so what I did is removed the 2413u from the zee. Got the zwave set up and rebooted.
      I then inserted the 2413u usb cable. I made sure I picked the opposite port address and then started the plugin. This time everything worked well.
      rkshack
