Updated to 3.0.1.6 nothing works
    Everything was working ok. Got e message in the log saying curent version would expire in 6 days. Upgraded to latest version and it said I had no licence. Bought the licence but now it doesn't work. Restarted HS and when I try to control a light I get this in the log.
    Jun-20 8:22:01 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 44
    Jun-20 8:22:01 PM ISYInsteon SetIOMulti : SetIOMulti set 44 to value -1
    Jun-20 8:22:01 PM Device Control Device: Bathroom to Toggle (-1) by/from: CAPI Control Handler
    Something must of happened when the plug-in started that was the ultimate cause of that error.
    At this point it is saying that the HomeSeer record doesn't match any device that was queried from the ISY. So either the initial query didn't work or something happened such that it failed to link the the ISY device with the HomeSeer device.
    Check the log for the time period when the plug-in was started and look for any errors.
    Also, check the device configuration. The technology address should map to your actual device Insteon address (Since it has a toggle, I'm assuming it's an Intsteon device)
    If you don't see anything that points to an obvious cause, bump up the plug-in's log level to notice, restart the plug-in and send me the log - bpaauwe at yahoo dot com
    Bob Paauwe
    ISYInsteon Plug-in
    http://www.bobsplace.com/ISYInsteon/
      For some reason there has been a additional digit added to the technology address off all my devices. For example my bathroom switch(yes insteon) has this address in HS 18 19 B9 1 and it shouldn't have the extra 1 at the end. All my devices are the same except some have 2 or 3 or 4.... How can I fix this? I can't seem to change this in the devices tabs. And I'd rather not have to change them all by hand.
        The extra digit is correct. The ISY adds that to all the devices. The ones that have a 2, 3, etc. mean those devices have multiple functions, like an 8 button keypad should show up as 8 devices under the same Insteon address with the extra digit representing each individual button.
        Devices like sensors that have a battery will have an extra function for the low battery notification so that will show up with extra digit of 2 or 3.
        If you look at the same device in the ISY admin console, it will show the same extra digit after the address under the device name.
        Bob Paauwe
        ISYInsteon Plug-in
          Email sent. I restored HS3 from a few days ago. ISY plugin was on 3.0.0.41. Tried the update again and the same thing happened.
            I have the same exact errors. Updating to 3.0.1.6 killed all my devices and I can no longer control them from HS.
            Jul-07 12:10:35 AM	 	ISYInsteon	SetIOMulti : ISY device mapping failure: No matching record for ID 956
            Jul-07 12:10:35 AM	 	Device Control	Device: Office Lights Overhead Lights to Fast On (-12) by/from: CAPI Control Handler
            Jul-07 12:10:33 AM	 	ISYInsteon	SetIOMulti : ISY device mapping failure: No matching record for ID 956
            Jul-07 12:10:33 AM	 	Device Control	Device: Office Lights Overhead Lights to Off (0) by/from: CAPI Control Handler
            Jul-07 12:10:32 AM	 	ISYInsteon	SetIOMulti : ISY device mapping failure: No matching record for ID 956
            Edit, I will also say that starting up this version took forever even though the log said it took 28ms.
              I tried to restore just the plugin back to 3.0.1.3 but now it says in the logs there are 0 devices owned by this plugin.
              I am going to do a full restore from this mornings back up of HS3. I will edit this post with the outcome (instead of creating a new one)
              Jul-07 12:23:49 AM	 	ISYInsteon	connect : Connecting to
              Jul-07 12:23:49 AM	 	ISYInsteon	Device record verification complete.
              Jul-07 12:23:49 AM	 	ISYInsteon	ISYInsteon Plug-in initialization complete.
              Jul-07 12:23:49 AM	 	ISYInsteon	ValidateDevices : Found 0 devices owned by ISYInsteon Plugin.
              Jul-07 12:23:47 AM	 	ISYInsteon	Verifying HomeSeer device records, this may take a while.
              Jul-07 12:23:47 AM	 	ISYInsteon	SubscribeToISY : Subscription thread waited 120 seconds for ready.
              Jul-07 12:23:47 AM	 	ISYInsteon	Initialize : ISY initialization failed to locate an ISY on the network.
              Jul-07 12:23:47 AM	 	ISYInsteon	IsyAutoDetect : ISY initialization failed to locate an ISY on the network.
              Jul-07 12:23:47 AM	 	ISYInsteon	GetDescURL : ISY initialization failed to locate an ISY on the network.
              Jul-07 12:23:47 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:41 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:40 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:37 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:32 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:31 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:28 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:27 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:21 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:17 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:11 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:10 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:09 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:08 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:07 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:23:01 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:57 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:51 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:47 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:41 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:40 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:39 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:38 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:37 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:36 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:34 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:33 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:32 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:31 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:28 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:27 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:26 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:21 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:20 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:19 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:17 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:11 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:07 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:22:01 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:21:58 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:21:57 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:21:51 AM	 	ISYInsteon	IsyAutoDetect : Found a NON-ISY UPNP device.
              Jul-07 12:21:47 AM	 	ISYInsteon	I have connected to HS
              Edit: I also see it says it can't find an ISY, which is odd. I'm investigating further.
                For now please ignore my posts. I think my ISY is somehow hosed. I can't connect directly to it. I know it worked earlier today.
                  Yup. My ISY is stuck in a boot loop. It worked around 8pm last night but by midnight I guess something happened and it's just booting over and over. Posted over at the ISY forums, but I guess I have to decide if I want to replace it or go another route.
                    That sucks. Hopefully UDI can get you back up and running. Maybe the firmware got corrupted, I believe there's a way to force re-load the firmware on boot.
                    Bob Paauwe
                    ISYInsteon Plug-in
