I'm on version 3.0.1.6. I selected the new update 3.0.1.8 from the 'manage plugins' page, but it always fails. I've tried restarting HS3, but the same results. Any suggestions?
V3.0.1.8: "Install/Update of package ISYInsteon failed.
Originally posted by CJVann View PostI'm on version 3.0.1.6. I selected the new update 3.0.1.8 from the 'manage plugins' page, but it always fails. I've tried restarting HS3, but the same results. Any suggestions?
I just rolled back to 3.0.1.6 and then updated through the manage plug-in's page. I did have to disable the plug-in first before doing the update as trying to update while the plug-in was running did fail since it couldn't overwrite the files while they are in-use.
HS3 keeps creating multiples of some devices. I delete them, restart HS3, and they soon come back again. Same reference number created multiple times. "Lamps" is a scene made up of Lamp 1 and Lamp 2. I almost wonder if it creates an entry for (Scene + Each member of the scene)?
EG: Lamps (Scene), Lamps + Lamp 1, Lamps + Lamp 2, Lamp 1, Lamp 2. There is only "Lamps Scene" and Lamp 1 and Lamp 2 in the ISY.
So maybe setting up all these associations between the devices and scenes wasn't such a good idea.
Also, the Device Status page doesn't show many of the devices in each room now. They are present on Device Management, but not Device Status (even if you reset all tabs, only a few of the room's devices show up). They are not "Hidden" devices.
