Hi,
I'm trying to use EasyTrigger & ISYInsteon to set a device value to an ISY state variable when the device value changes (and vice versa)
Using 2 events, I have achieved partial success.
First event:
If sVolume (ISY state var) has a value that just changed
THEN
Set Device Chromecast Volume to sVolume
This event is working
My second event is not working and I can't figure out why:
If Chromecast Volume has a value that just changed
THEN
Set Device sVolume to Chromecast Volume
Interestingly, in the HomeSeer Device List, the value for sVolume does change based on Chromecast Volume, BUT this change is not reflected in the ISY. If I click "submit" then the change appears in the ISY. It just seems like for some reason the device change isn't making it to the ISY for some reason. When I use "ISYInsteon ISY Device Actions" I can successfully change ISY variables but can't use Homeseer variables here.
I'm not sure if this is a problem with ISY insteon or EasyTrigger. Any help you can provide would be great.
Ben
First event:
THEN
THEN
Ben
