Config Change
    Config Change
    I keep getting this in the log. I get it every minute. Was is causing this.
    HTML Code:
    Dec-21 5:23:00 PM         ISYInsteon    CONFIG_CHANGE: Events Saved  type = 1  ddd = 0  dac = 0
    HTML Code:
    I don't know specifically what on your system is causing it. It's a debug message I accidentally left in the plug-in. It happens when HS sends a configuration change event to all the plug-ins. During my experimentation with this, it only happened when editing HS events.
    I've removed this from the plug-in so the next version won't be doing this.
    Bob Paauwe
    ISYInsteon Plug-in
    http://www.bobsplace.com/ISYInsteon/
      freeon, do you have any events that are creating delayed actions for a device? If so those are creating temporary events in HS which is being logged by the ISY plugin. I'm getting 100's to almost 1000 of these a day as my motion sensors keep modifying delayed actions to turn the lights off after x minutes of no motion.... This should go away once the next version of the plugin is released.....
        Just uploaded a new version that removes the message.
        Bob Paauwe
        ISYInsteon Plug-in
