I have been using your plugin almost from the first time you posted it and it's working fine overall but there is one thing that is really annoying that have always caused me some trouble.
I'm not a native english speaker so I rename on/off and statuses to my native langage. I also make changes to the status icons an sometimes even move the buttons around. This is usually not a problem but with this plugin all is reset back to default when the plugin is updated, restarted or now when I upgraded HS3 to latest version. When this happen I need to manually update everything again.
In some cases I have made a virtual device that I change to my liking that uses the default plugin setup and this works quite well but that also brings a lot of extra work.
I suspect that you are native english speaking and maybe most of the users here are and that would be the reason that no one have reported this before.
Other than the above everything is working fine. I do miss some, for me, quite important dpt's though but I can post them later in the feature requests thread. I just want this basic stuff, described above, fixed first. Can you make this happen for us who do not use an english UI? Is it something that I'm doing incorrect? Please enlighten me in that case.
Best regards
Christian
Best regards
Christian
