devies usage in scripts not correct working
  • devies usage in scripts not correct working
    I use the below script to display the temperture. In device view i see the correct T but the below statement constantly show the value -1. I do the same with a RFXCOM sensor and that went wel. What do i do wrong? The KNX device has the code J1.
    hs.WriteLogEx("Status", "Buiten Temperatuur KNX :" & hs.DeviceValue(hs.GetDeviceRef("J1")) & " graden ","#008000")
    thnx
    Problem is solved. Instead of J1 i need to use the Technology Address : izKNX-TEMPERATURE-J1
