Salut !
I just installed Jeedom again. I see that the plugin is visually better !
I just installed the alexa-api plugin on the Jeedom side. But i do not see any control or value out of it. Maybe Jeedom modified something on their side?
Or is that just for the Alexa-api plugin?
I was able to send a command to 3 different echo with this hs formatted one line string http get.
I prefer to send command this way, it is only making one api call. But I would like to install the plugin at my mother place, so..it would be faster for me to get the controls by the plugin.
Thank you.
&hs.GetURL("192.168.1.xxx","/core/api/jeeApi.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxx&type=cmd&id=%5B53 %2C149%2C101%5D",TRUE,PORT)
Thank you.
