Description :
This plug-in is designed to allow HS3 to monitor and control Jeedom equipments.
Bring your home automation system to the next level by combining the power of HomeSeer HS3 and Jeedom.
Jeedom is an open source home automation solution that can be installed on:
More information on Jeedom and installation instructions can be found here.
This plugin works with both Windows and Linux version of HS3 (Mono 5.18 recommended for Linux version). User Guide can be downloaded here.
The plugin can be downloaded from the Utilities section of the updater.
Revision History:
Version 1.4.2.0
Version 1.4.1.0 (18-Jan-19) :
Version 1.3.2.0 (21-May-18) :
Version 1.3.1.0 (28-Mar-18) :
Version 1.3.0.0 (27-Sep-16) :
Version 1.2.0.0 (12-Feb-16) :
Version 1.1.0.0 (24-Dec-15) :
Version 1.0.0.0 (24-Nov-15) : Initial release.
- A Raspberry Pi 1 or 2
- A Hummingboard i1, i2 ou i4
- A Synology NAS
- Any system based on Linux (Debian is prefered)
Revision History:
Version 1.4.2.0
(28-Mar-19) : MANDATORY UPDATE FOR JEEDOM v3.3.x and above
- Changed :
- Compatibility fix for Jeedom 3.3.x (adaptation to jsonAPI changes)
- Bugs fixed :
- Jeedom IP/API key test improvement
- Added :
- In Jeedom 'Config' page : It is now possible to specify a port with the Jeedom server IP address (JeedomSDK).[
- Bugs fixed :
- When % range is selected for a slider, the calculated % value is now rounded to the nearest integer.
- Fix for compatibility with Jeedom 'mobile' plugin (JeedomSDK).
- Changed :
- 'Device' page performance has been greatly improved : Jeedom 'Equipment' are now grouped under a sliding tab corresponding to their associated Jeedom 'Object'.
- Newtonsoft.Json.dll updated to latest version (12.0.1).
- JeedomSDK updated to 1.2.1.0.
- Windows and Linux plugin packages are now identical.
- Changes :
- Moved to the new updater system (no change in the plugin code)
- Bugs fixed :
- Special characters in string value received from Jeedom in Push mode were not managed correctly translated.
- Added :
- Slider range can now be specified in % or using the Min/Max values defined in Jeedom
- Bugs fixed :
- Color status was not managed correctly in push mode (always to 0).
- Compatibility improved for devices providing color Status and command.
- Added :
- Action 'Jeedom : Set Color' has been added, making it possible to change a device Color form an event (tested with fibaro RGBW module and Philips Hue bulbs and Lightberry)
- A 'Setcolor' function has been added. This function can be called in a script using 'hs.pluginfunction' (see plugin documentation for usage)
- Bugs fixed :
- HS3 Devices associated to Jeedom Slider have now their 'dimmable' attribute set.
- Fixed an issue preventing setting a dim value in an event action.
- Untagged 'Legacy Mode' (former 'DIY Mode') in config page not taken into account at plugin startup.
- Changes :
- .dll are now stored in bin/Jeedom.
- 'DIY Mode' in config page renamed as 'Legacy Mode'.
- When a Jeedom action corresponds to a color, the HS3 associated device control is set to a color picker control with a range 0 to 16777215.
- When a Jeedom info correspond to color :
- Its associated HS3 device string is set to a plain block with font color corresponding to the Jeedom info color.
- Moving the mouse over the block shows the hex code in a tooltip.
- Its associated HS3 device value is set to a (double) value corresponding to the HEX value of the Jeedom info color.
- Added :
- HOT : Push from Jeedom implemented - Drastically reduce CPU load ! Can be combined with automatic Polling to secure data consistency between Jeedom and HS3. Refer to plugin documentation for proper setup.
- Bugs fixed :
- 'DIY mode' / 'Enable Trace' messed up in config file resulting to configuration not correctly saved/restored.
- API key validity indicator to red even if the key is OK wne read from config file.
- Changes :
- 'space' char between Value and Unit removed for temperature.
- HS3 device string is not set if a value/status pair is defined for the value.
- Bugs fixed :
- Server IP change in the config page is now correctly taken into account (no more plugin restart needed).
- Resolved conflict issue with Zibase plugin that prevent access to Config and Device pages.
- Compatibility with Jeedom installed using and image file (see also added section).
- Added :
- New 'DIY install' option added on config page to take into account if your Jeedom was installed manually or using a Disk Image.
- Additional traces at statup and when config is changed (only when logfile is activated).
- Others :
- Changes in JeedomSDK (v1.1.0.0) prototype taken into acccount.
