Greetings, everyone!
I am trying to do something that should be simple. but...
I use a Cooper Aspire RF 5-button keypad for a bunch of light scenes in my master bedroom and master bath. I also have a Philips Hue in master bath, with one light strip and three bulbs linked together into one "room" in the Hue app. I used this plugin to capture one of the scenes in my master bathroom, after I triggered that scene from Philips Hue app.
I want to be able to turn this scene on and off using a physical light switch, as well as trigger it using events. So, I thought, I can use one of my unused keypad buttons on Coope keypad. I created an event, so that when the button on the keypad is turned on, JowiHue scene "Master Bath" is activated. I haven't even tested it yet.
I made a copy of that event and was going to change it so that turning the button off turns the scene lights off via JowiHue plugin. Can't do that. Under actions, when creating an event, there is a way to load a JowiHue scene, but not to "unload" or turn off.
I don't want to use HS to literally turn those lights / lamps off, which I can for wall lamps (not for the LED Hue strip. The wall lamps that now have Hue lights in them, are always On in HomeSeer, otherwise they will not be reachable for the Hue bridge.
So now, when I turn the scene via Hue app, I can turn it on and, obviously, turn it off. Using JowiHue plugin, I can't figure out how to turn the scene OFF...
