Error Crashing HS3
  • #16
    kwatt,
    All I can see is that the plugin trips while it is being closed. It is closed becuase HS3 closes. Why HS3 closes I don't know.
    The JowiHue plugin has several timers to be able to control the bridge. One of these timers is still triggering while being closed causing a closure error. I am trying to find it, but that is quite tough to find.
    As for HS3 closing, I don't really know how to help you out as there are many options.
    Are you running HS3 through taskplanner? then, is the option "end task when it runs for mor then xx days" active maybe?
    Wim
    -- Wim
    • #17
      Hi Wim,
      No I'm not running anything like that at all.
      I tried it with Jowi Hue closed though and it did still fall over so it may be HS3.
      K.
      • #18
        K.
        So we can exclude the plugin for now. When you look at the HS3 log, just before it crashes (use filter options in the log page to select date and time before the crash), is there a common event maybe that runs just before every crash?
        Wim
        -- Wim
        • #19
          I think I've fixed it but reinstalling HS3.
          For now it all seems back to normal so here's hoping that whatever it was just needed a reinstall.
          To be honest, I'm not much caring so long as it's fixed and working truth be told.
          K.
          • #20
            I understand fully, same here
            Crossing fingers....
            -- Wim
            • #21
              Hi Wim,
              Just thought I'd let you know, two weeks or so and all is well, no issues.
              K.
              • #22
                great to hear!!!
                Wim
                -- Wim
                • #23
                  kwatt,
                  Wim
                  Found my problem.
                  sorry I was posting to different thread.
                  3 days was my issue thank you for suggesting this.
