I have dedicated a rpi3 to deConz and the RaspBee. I have a small network of Hue lights, sensors and switches and a couple of other Zigbee lights. But the load average doesn't go above 0.15 and the deConz cpu stays below 10%. I am thinking of using that rpi3 to do other tasks, possibly run the JowiHue plug-in remotely.
Beta JowiHue: adding support for RaspBee and ConBee gateway
Originally posted by mhn View PostHi Wim.
Change to router and back - leave and rejoin.
No luck and CPU high again.
I will send you detailed log om mail.
Regards
Morten
Registration of the deCONZ gateway on a different webport is what went wrong. This is corrected now in 2.0.0.21, which I will send to the updater today!
Wim-- Wim
Hi - is there any way to get the new version before it arrives in the updater? My ConBee arrived today and I can't register the DeConZ gateway as a bridge with the plugin. It's on port 8080.
(Alternatively, is there a way to change the port DeConZ uses? and if so, which port is JowHue looking for?)
Jon.
Jon,
Yeah, for some reason HST is taking more time to publish the new beta.
The port is chosen by deCONZ and is not yet configurable by the user. The request for that is out already, but not yet honoured.
The plugin can handle the different port perfectly, but indeed missed on the registration part. I have send you a PM on that.
Wim-- Wim
All,
the new beta, 2.0.0.21 is published now. This solves an issue with the deCONZ interface using a non 80 port. This would cause registration of the gateway to go wrong. It now should be ok, with deCONZ choosing its own port.
Wim-- Wim
Originally posted by w.vuyk View PostDiderik,
Keep us posted here, I am guessing others might want to know too here
Wim
Originally posted by w.vuyk View PostThe port is chosen by deCONZ and is not yet configurable by the user. The request for that is out already, but not yet honoured.
Code:/usr/bin/deCONZ-autostart.sh
HTML Code:--http-port=80
Diderik,
The manual port adding seems not to work - at least that is I read on the github... there is an method but then you have to recompile? Anyway, it is on the list for a future version.
Hope you get everything over... if you have sensore, those are the biggest win on deCONZ For me the remote from IKEA and the Xiaomi cube are my favorites now
Wim-- Wim
Originally posted by w.vuyk View PostHope you get everything over... if you have sensore, those are the biggest win on deCONZ For me the remote from IKEA and the Xiaomi cube are my favorites now
One firmware update away...HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Running on Windows 10 (64) virtualized on ESXi (Fujitsu Primergy TX150 S8).
Originally posted by w.vuyk View PostThe manual port adding seems not to work - at least that is I read on the github... there is an method but then you have to recompile?
Originally posted by Moskus View PostOoooh, I'm so looking forward to make that work!
Hi Wim.
I had a lot of trouble getting Ikea Remote and PIR on deCONZ today.
I succeded at last but got errors in the HS log. ( No detailed sorry.)
okt-07 17:39:18 JowiHue Extra info: 0-0-1174-3
okt-07 17:39:18 JowiHue Error: (HSEvent):Error running config change:Min (7) must be less than or equal to max (-1) in a Range object.
okt-07 17:39:17 JowiHue Motion devices created for TRADFRI motion sensor
okt-07 17:39:17 JowiHue Battery device created for sensor TRADFRI motion sensor
okt-07 17:39:16 JowiHue Motion device created for sensor TRADFRI motion sensor
okt-07 17:34:13 JowiHue Extra info: 0-0-1173-3
okt-07 17:34:13 JowiHue Error: (HSEvent):Error running config change:Min (6) must be less than or equal to max (-1) in a Range object.
Theres no batteri device for the remote.
Everything seems to work.
Bulbs where no trouble.
Regards
Morten
Morten,
Indeed I had my set of difficulties adding the motion sensor and remote of IKEA... Especially when you have the old firmware it can take quite some tries to join the devices with deCONZ. What I learned was that it is good to wathc the deCONZ device map at the same time. Quite often the device is already present but you need to press buttons/keep moving to let all the capabilities arrive in deCONZ, if you press the right (almost invisible) circle on the device in the interface you will get to see the endpoints discovered.
As long it did not yet get all the properties, the plugin will not be able to 'see' the new device yet.
The errors you are seeing are coming somehow through the HSEVENT actions of Homeseer. It could be initial responses while the sensors are not yet fully defined in the plugin. Will play with that by removing/adding sensors here. I should be able to copy the issues here.....
I will also check why the remote does not come with the battery device, I have the battery device here, so maybe I missed it due to some of my later changes.
Wim-- Wim
I am running the latest beta from the updater (v2.0.0.21) and deCONZ on the same machine as Homeseer. I had the bridge scanned and registered but on restarting Homeseer, the plugin is unable to see the bridge again.
I can remove, re-scan and re-register the deCONZ bridge again, but the plugin then immediately logs an error:
Oct-10 12:46:03 JowiHue Warning: IP address 192.168.3.135 reachable, known as ip address for a bridge, but is no longer recognised as bridge....
Oct-10 12:45:48 JowiHue Registration of bridge was succesfull
Oct-10 12:45:16 JowiHue ============================================================ ================================
Oct-10 12:45:16 JowiHue ------------------------------------------NEW Bridge ---------------------------------------
Oct-10 12:45:16 JowiHue Info: Unregistered bridge found at IP address 192.168.3.135
Oct-10 12:45:16 JowiHue Please register this bridge in the configuration page
Oct-10 12:45:13 JowiHue Pressed button for immediate scan for bridges - scanning started
deCONZ is running on port 8080. I changed the HS SSL port to 444 to make sure that was 'out of the way' but still can't retain a connection between the plugin and deCONZ...
Any ideas?
Jon.
Jon,
Yes, I already found the issue here. I need to iron out the last bits here, then I will send you a pm how to download the new version to test... should be in a few hours ok?
Wim-- Wim
