Hue Dimmer Errors in Log
  • Hue Dimmer Errors in Log
    Shortly after upgrading to HS3 3.0.0.368, I started getting an error about my hue dimmers in the log file every few seconds. The two Hue dimmer switches are working properly outside of HS3 and I see them both listed in the dimmer switch panel of the jowihue config. Any ideas?
    Aaron
    MESSAGE BOARD (copy/paste section below to message board posts)
    Current Date/Time: 9/28/2017 11:50:17 PM
    HomeSeer Version: HS3 Standard Edition 3.0.0.368
    System Uptime: 0 Days 1 Hour 34 Minutes 36 Seconds
    IP Address: 192.168.1.22
    Number of Devices: 268
    Number of Events: 57
    Available Threads: 200
    Enabled Plug-Ins
    1.0.0.142: Arduino Plugin
    2.0.47.0: BLBackup
    2.0.22.0: BLUPS
    3.6.5.0: Harmony Hub
    1.1.11.0: Honeywell WiFi Thermostat
    3.0.0.20: ImperiHome
    1.1.3.1: JowiHue
    0.0.0.34: Pushover 3P
    1.0.0.5: Restart
    3.0.0.21: Sonos
    3.0.6440.19101: UltraMon3
    3.0.1.130: Z-Wave
    Sep-28 11:52:55 PM JowiHue Error: (UpdateSensors):sensorrow Sensordevice present, but no sensor on bridge! **************************** Object info ***************************** Type: MySensorsTableRow Fields: None Properties: System.String BridgeSerial=001788FFFE1792FB System.String ID=6 System.String name=Hue dimmer switch 2 System.String modelid= System.String type="CLIPGenericFlag" System.String manufacturer= System.Object sensorconfig= System.String uniqueid= System.String swversion= System.Object sensorstate= System.String ref=496 Int16 batteryref=497 System.String productid= Double correction=0 System.String RowError= System.Data.DataRowState RowState=2 Boolean HasErrors=False ************************* End Object info ***************************
    Sep-28 11:52:53 PM JowiHue Error: (UpdateSensors):sensorrow Sensordevice present, but no sensor on bridge! **************************** Object info ***************************** Type: MySensorsTableRow Fields: None Properties: System.String BridgeSerial=001788FFFE1792FB System.String ID=6 System.String name=Hue dimmer switch 2 System.String modelid= System.String type="CLIPGenericFlag" System.String manufacturer= System.Object sensorconfig= System.String uniqueid= System.String swversion= System.Object sensorstate= System.String ref=496 Int16 batteryref=497 System.String productid= Double correction=0 System.String RowError= System.Data.DataRowState RowState=2 Boolean HasErrors=False ************************* End Object info ***************************
    Sep-28 11:52:51 PM JowiHue Error: (UpdateSensors):sensorrow Sensordevice present, but no sensor on bridge! **************************** Object info ***************************** Type: MySensorsTableRow Fields: None Properties: System.String BridgeSerial=001788FFFE1792FB System.String ID=6 System.String name=Hue dimmer switch 2 System.String modelid= System.String type="CLIPGenericFlag" System.String manufacturer= System.Object sensorconfig= System.String uniqueid= System.String swversion= System.Object sensorstate= System.String ref=496 Int16 batteryref=497 System.String productid= Double correction=0 System.String RowError= System.Data.DataRowState RowState=2 Boolean HasErrors=False ************************* End Object info ***************************
    Sep-28 11:52:49 PM JowiHue Error: (UpdateSensors):sensorrow Sensordevice present, but no sensor on bridge! **************************** Object info ***************************** Type: MySensorsTableRow Fields: None Properties: System.String BridgeSerial=001788FFFE1792FB System.String ID=6 System.String name=Hue dimmer switch 2 System.String modelid= System.String type="CLIPGenericFlag" System.String manufacturer= System.Object sensorconfig= System.String uniqueid= System.String swversion= System.Object sensorstate= System.String ref=496 Int16 batteryref=497 System.String productid= Double correction=0 System.String RowError= System.Data.DataRowState RowState=2 Boolean HasErrors=False ************************* End Object info ***************************
    Sep-28 11:52:48 PM JowiHue Error: (UpdateSensors):sensorrow Sensordevice present, but no sensor on bridge! **************************** Object info ***************************** Type: MySensorsTableRow Fields: None Properties: System.String BridgeSerial=001788FFFE1792FB System.String ID=6 System.String name=Hue dimmer switch 2 System.String modelid= System.String type="CLIPGenericFlag" System.String manufacturer= System.Object sensorconfig= System.String uniqueid= System.String swversion= System.Object sensorstate= System.String ref=496 Int16 batteryref=497 System.String productid= Double correction=0 System.String RowError= System.Data.DataRowState RowState=2 Boolean HasErrors=False ************************* End Object info ***************************
    Sep-28 11:52:47 PM JowiHue Plugin succesfully started
    Sep-28 11:52:47 PM JowiHue Debug: (InitPlugin) Config Done InitOK=True
    Sep-28 11:52:47 PM JowiHue ============================================================ ==================================
    Sep-28 11:52:47 PM JowiHue 1 Animations available for use in this plugin
    Sep-28 11:52:47 PM JowiHue 4 Local scenes available for use in the JowiHue plugin
    Sep-28 11:52:47 PM JowiHue 22 Presets available for use in the JowiHue plugin
    Sep-28 11:52:47 PM JowiHue -------------------------------------Plugin info ---------------------------------------------
    Sep-28 11:52:47 PM JowiHue 2 Generic status sensor found on bridge 'Philips hue'
    Sep-28 11:52:47 PM JowiHue 1 Daylight sensor found on bridge 'Philips hue'
    Sep-28 11:52:47 PM JowiHue 2 Dimmer switch(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
    Sep-28 11:52:47 PM JowiHue 8 Groups available on bridge 'Philips hue'
    Sep-28 11:52:47 PM JowiHue 15 lights connected to bridge 'Philips hue'
    Sep-28 11:52:47 PM JowiHue -------------------------------------Bridge info ---------------------------------------------
    Sep-28 11:52:47 PM JowiHue Debug: (RefreshDevices) RefreshDevices finished succesfully for bridge Philips hue
    Sep-28 11:52:47 PM JowiHue Debug: (InitPlugin) Refreshing Bridge
    Sep-28 11:52:47 PM JowiHue Debug: (InitPlugin) 1 registered bridge(s) found
    Sep-28 11:52:47 PM JowiHue Debug: (InitPlugin) Starting Device checks
    Sep-28 11:52:47 PM JowiHue Debug: (InitDevices) InitDevices: End Hue Device search
    Sep-28 11:52:47 PM JowiHue Debug: (InitDevices) InitDevices: Searching for Hue devices
    Sep-28 11:52:47 PM JowiHue Debug: (Bridgescan) Start Scan for bridges 9/28/2017 11:52:47 PM
    Sep-28 11:52:46 PM JowiHue * Connected to bridge Philips hue at 192.168.1.53
    Sep-28 11:52:46 PM JowiHue Debug: (InitialBridgeScenes) starting for 'Philips hue'
    Sep-28 11:52:46 PM JowiHue Debug: (GetSensorCorrection) Returning 0 for WA0001
    Sep-28 11:52:46 PM JowiHue Debug: (GetSensorCorrection) Returning 0 for 00:17:88:01:10:49:66:81-02-fc00
    Sep-28 11:52:46 PM JowiHue Debug: (GetSensorCorrection) Returning 0 for 00:17:88:01:10:49:66:80-02-fc00
    Sep-28 11:52:46 PM JowiHue Debug: (InititialSensors) starting for 'Philips hue'
    Sep-28 11:52:46 PM JowiHue Debug: (InitialRules) starting for 'Philips hue'
    Sep-28 11:52:46 PM JowiHue Debug: (InitialGroups) starting for 'Philips hue'
    Sep-28 11:52:46 PM JowiHue Debug: (InitialLights) starting for 'Philips hue'
    Sep-28 11:52:44 PM JowiHue Debug: (FindBridgesSelf) InitDevices: Searching for Hue devices
    Sep-28 11:52:44 PM Plug-In Finished initializing plug-in JowiHue
    Sep-28 11:52:44 PM JowiHue Debug: (InitPlugin) InitPlugin: initial checks
    Sep-28 11:52:44 PM JowiHue InitIO:Plugin basic initialisation done
    Sep-28 11:52:44 PM JowiHue Debug: (MainWatchTimer) Checking plugin health 9/28/2017 11:52:44 PM
    Sep-28 11:52:44 PM JowiHue Debug: (GetAnimations) GetAnimations finished normal
    Sep-28 11:52:44 PM JowiHue Debug: (InitScenes) GetScenes finished normally
    Sep-28 11:52:44 PM JowiHue Debug: (InitIO) Database location Data Source=C:\Program Files (x86)\HomeSeer HS3/Data/JowiHue/JowiHue.db;Version=3;Pooling=True;Max Pool Size=100;
    Sep-28 11:52:44 PM JowiHue Starting plugin JowiHue 1.1.3.1 on Windows
    Sep-28 11:52:43 PM Info Plugin JowiHue has connected. IP:127.0.0.1:52565
    Sep-28 11:52:37 PM Info Plugin JowiHue with instance: has disconnected
    Sep-28 11:52:37 PM JowiHue JowiHue Plugin is stopped. Thanks for using it :-)
    Sep-28 11:52:37 PM Plug-In Shutting down Plug-In: JowiHue
    Sep-28 11:51:49 PM JowiHue Error: (BuildDimmerOverview)immers: Object reference not set to an instance of an object.
    Sep-28 11:51:23 PM JowiHue Debug: (Bridgescan) End search for bridges
    Sep-28 11:50:52 PM JowiHue Debug: (Bridgescan) Start Scan for bridges 9/28/2017 11:50:52 PM
    Sep-28 11:50:50 PM JowiHue Debug: (MainWatchTimer) Checking plugin health 9/28/2017 11:50:50 PM
    Sep-28 11:48:50 PM JowiHue Debug: (MainWatchTimer) Checking plugin health 9/28/2017 11:48:50 PM
    Sep-28 11:46:55 PM JowiHue Debug: (InitialBridgeScenes) starting for 'Philips hue'
    Sep-28 11:46:55 PM JowiHue Debug: (GetSensorCorrection) Returning 0 for WA0001
    Sep-28 11:46:55 PM JowiHue Debug: (GetSensorCorrection) Returning 0 for 00:17:88:01:10:49:66:81-02-fc00
    Sep-28 11:46:55 PM JowiHue Debug: (GetSensorCorrection) Returning 0 for 00:17:88:01:10:49:66:80-02-fc00
    Sep-28 11:46:55 PM JowiHue Debug: (InititialSensors) starting for 'Philips hue'
    Aaron,
    It looks like the plugin is complaining about one Hue Dimmer only, the "Hue dimmer switch 2" is the one having an issue. I know there is a problem regarding dimmers in 1.1.3.1 that has been solved in the new beta here.
    A work around for you would be to remove this dimmer from the device list (without the plugin active) and let the plugin recreate the device. It could solve the issue for some time, but it might reoccur.
    I doubt (hope) this is not caused bu the .368 version of HS3, but there is a lot going on lately with new versions of HS3. Stayed out of it for now, but might go for a test with it as I hear of some more issues there.
    Another alternative would be installing the beta version of the plugin - but still removing the dimmerdevice, so the plugin can recreate the device. This should be a more stable solution - if HS3 3.0.0.368 is not the issue.
    Wim
    -- Wim
      I've installed the beta and re-added the dimmer switch and there are no more errors in the log file.
      I noticed the status graphics/values aren't present for the dimmer switches now (?). I had to use the numeric values in my events instead of "on/off,etc", but they work fine.
      thanks!
        aaron,
        Thanks for the confimation
        The statusses seem to fail to show correct then... could you post a image of the properties of the dimmer device, the JowiHue tab in it and the graphics/pairs page?
        Wim
        -- Wim
          aaron,
          Wim
          Sure -
            Aaron,
            That proves there is an error in my plugin. The dimmer devices itself is working correctly, so just go ahead and use it. I will have to puzzle on it here...
            Thanks!
            Wim
            -- Wim
              I have the same problem with a Hue Dimmer.
              I also see the error 'Object reference not set to an instance of an object.'
              Did you found a fix for it?
                idplusse,
                I answered in your original thread. It should have been resolved in the latst version, 2.0.1.0?
                Wim
                -- Wim
