Plugin in dead state after power restoration?
  • Plugin in dead state after power restoration?
    Hi,
    A storm took out power for 12 hours today. Upon power restoration my HomeSeer server started up far faster than the Philips Hue bridge did. I was looking at my logs and noticed the plugin seemed to remain in a dead state until I manually disabled/enabled the plugin. Should it have reattempted to discover the local bridge and finish its start-up tasks, or is this dead state the currently expected behavior?
    Log below.
    Oct-30 4:49:32 PM	 	JowiHue	1 Temperature sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
    Oct-30 4:49:32 PM	 	JowiHue	1 Lightlevel sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
    Oct-30 4:49:32 PM	 	JowiHue	1 Daylight sensor found on bridge 'Philips hue'
    Oct-30 4:49:32 PM	 	JowiHue	2 Generic status sensor found on bridge 'Philips hue'
    Oct-30 4:49:32 PM	 	JowiHue	-------------------------------------Plugin info ---------------------------------------------
    Oct-30 4:49:32 PM	 	JowiHue	23 Presets available for use in the JowiHue plugin
    Oct-30 4:49:32 PM	 	JowiHue	2 Local scenes available for use in the JowiHue plugin
    Oct-30 4:49:32 PM	 	JowiHue	1 Animations available for use in this plugin
    Oct-30 4:49:32 PM	 	JowiHue	==============================================================================================
    Oct-30 4:49:32 PM	 	JowiHue	Plugin succesfully started
    Oct-30 4:49:32 PM	 	JowiHue	Enabled Colour Temperature control for group Garage
    Oct-30 4:49:32 PM	 	JowiHue	-------------------------------------Bridge info ---------------------------------------------
    Oct-30 4:49:32 PM	 	JowiHue	15 lights connected to bridge 'Philips hue'
    Oct-30 4:49:32 PM	 	JowiHue	14 Groups available on bridge 'Philips hue'
    Oct-30 4:49:32 PM	 	JowiHue	1 Motion sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
    Oct-30 4:49:32 PM	 	JowiHue	Enabled Hue control for group Garage
    Oct-30 4:49:31 PM	 	JowiHue	Enabled Colour Temperature control for group Master Bathroom
    Oct-30 4:49:31 PM	 	JowiHue	Enabled Hue control for group Master Bathroom
    Oct-30 4:49:30 PM	 	JowiHue	Enabled Colour Temperature control for group 2nd Floor Hallway
    Oct-30 4:49:30 PM	 	JowiHue	Enabled Hue control for group 2nd Floor Hallway
    Oct-30 4:49:30 PM	 	JowiHue	Enabled Colour Temperature control for group Family Room
    Oct-30 4:49:30 PM	 	JowiHue	Enabled Hue control for group Family Room
    Oct-30 4:49:29 PM	 	JowiHue	Enabled Colour Temperature control for group Master Bed
    Oct-30 4:49:29 PM	 	JowiHue	Enabled Hue control for group Master Bed
    Oct-30 4:49:29 PM	 	JowiHue	Enabled Colour Temperature control for group HueHalloweenActiveLightsGroup
    Oct-30 4:49:28 PM	 	JowiHue	Enabled Hue control for group HueHalloweenActiveLightsGroup
    Oct-30 4:49:27 PM	 	JowiHue	Enabled Colour Temperature control for group Mud Room
    Oct-30 4:49:27 PM	 	JowiHue	Enabled Hue control for group Mud Room
    Oct-30 4:49:25 PM	 	JowiHue	* Connected to bridge Philips hue at 192.168.X.XXX
    Oct-30 4:49:24 PM	 	JowiHue	InitIO:Plugin basic initialisation done
    Oct-30 4:49:24 PM	 	JowiHue	Starting plugin JowiHue 2.0.1.0 on Windows
    .Above is where I manually re-enabled the plugin.
    .Below is from when power restored to when I manually stopped the plugin.
    Oct-30 4:49:17 PM	 	JowiHue	JowiHue Plugin is stopped. Thanks for using it :-)
    Oct-30 4:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):Object variable or With block variable not set.
    Oct-30 4:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0
    Oct-30 3:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):Object variable or With block variable not set.
    Oct-30 3:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0
    Oct-30 2:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):Object variable or With block variable not set.
    Oct-30 2:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0
    Oct-30 1:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):Object variable or With block variable not set.
    Oct-30 1:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0
    Oct-30 12:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):Object variable or With block variable not set.
    Oct-30 12:43:50 PM	 	JowiHue	Error: (CheckBridgeUpdate):CheckBridgeUpdate Version 1.21.0
    Oct-30 12:43:25 PM	 	JowiHue	Devices added for new light Mud Porch Ceiling 02
    Oct-30 12:43:25 PM	 	JowiHue	Devices added for new light Front Door Left
    Oct-30 12:43:23 PM	 	JowiHue	Devices added for new light Front Door Right
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Colour Temperature control for group 2nd Floor Hallway
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Hue control for group HueHalloweenActiveLightsGroup
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Colour Temperature control for group HueHalloweenActiveLightsGroup
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Hue control for group Garage
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Colour Temperature control for group Garage
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Hue control for group Family Room
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Colour Temperature control for group Family Room
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Hue control for group 2nd Floor Hallway
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Colour Temperature control for group Master Bathroom
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Hue control for group Mud Room
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Colour Temperature control for group Mud Room
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Hue control for group Master Bed
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Colour Temperature control for group Master Bed
    Oct-30 12:43:22 PM	 	JowiHue	Disabled Hue control for group Master Bathroom
    Oct-30 12:43:22 PM	 	JowiHue	Devices added for new light Mud Porch Door
    Oct-30 12:37:51 PM	 	JowiHue	Plugin succesfully started
    Oct-30 12:37:51 PM	 	JowiHue	InitPlugin:No registered bridge found; please register a bridge through the configuration page
    Oct-30 12:37:49 PM	 	JowiHue	Bridge device Philips hue not containing a valid IP address, was it reset?
    Oct-30 12:37:49 PM	 	JowiHue	Warning: warning! Missing ipaddress in device for bridge Philips hue, wil try repair
    Oct-30 12:37:49 PM	 	JowiHue	InitIO:Plugin basic initialisation done
    Oct-30 12:37:49 PM	 	JowiHue	Starting plugin JowiHue 2.0.1.0 on Windows
    scorp508,
    The log does not look dead to me? It is connected to the bridge?
    When the plugin starts without the bridge started, it should look every 5 minutes with UPNP to see if the bridge started. It would also show a warning in the log saying it has found a bridge device, but cannot reach the bridge.
    Wim
    -- Wim
      Hmm, maybe I was too focused on these...
      ...and the output looked much different from a traditional clean startup. I didn't think to try anything before stop/starting the plugin, just saw the errors so I bounced the plugin then saw the "normal" startup.
        Yes, the lines you are looking at is the check for a update of the Philips bridge. Philips is putting a lot of changes to the update proces. Am thinking of removing that as it is no longer really functioning correct in the plugin.
        Wim
        -- Wim
          Thanks, Wim, sorry for the false alarm.
            No problem at all. Will still check on this start without bridge active, want ot make sure it works and maybe throw some better warnings
            Wim
            -- Wim
