Second sensor did not respond...
  • Second sensor did not respond...
    I was so happy so I buyed some more sensors. Added one new, but then the problem started.. They both was registered in HS, with all four devices, but they did not update.. I start to delete the bridge and all accessory and lights.... restart the HS, restart the HS PC. Nothing happened.
    At last I reset the bridge. the devices are now registered on the Hue app.
    When they did not respond in HS, I saw that motion was detected in the app.
    After deleting and resetting, I cant register the accessories in HS again. Please help ?
    Solved after the last restart of the plugin
    Xian,
    Bit confused here.... it is solved now - no issues - after the restart?
    It should have updated after the addition of the sensors... will look at that initial part... wondering what might happen there.
    Wim
    -- Wim
