(Bridgescan):Invalid URI: The hostname could not be parsed.
  • (Bridgescan):Invalid URI: The hostname could not be parsed.
    I'm using Jowihue with a raspbee bridge and a hue bridge on Linux.
    Very pleased with it.
    However, since yesterday the following error appears in the log every 5 minutes:
    Jowihue is fully functional.
    I'm not aware of any changes I made to my configuration the last days.
    I suddenly started having the same problem yesterday running on Windows 10 with a hue bridge. Jowihue seems to be fully functional. No configuration changes were made before this started happening in the middle of the night.
      I am seeing the same here. It is coming from the meethue site where the plugin does a extra upnp call to be sure it has all the bridges.
      I guess some changes have been made on the site behind to http://www.meethue.com/api/nupnp
      -- Wim
        Have the same error, but also the plugin is restarting every 30 seconds or so
          Same Here
          I am having the same error. i cant even manually turn the light on or off from HS3 the plugin stops and the restarts
            Also here....... same issue. However I am dead in the water
            Here is where it started:
            ov-02 5:56:51 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
            Nov-02 5:51:51 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
            Nov-02 5:46:51 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
            Nov-02 5:41:51 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
            Then I may have dropped through a one way door after upgrading to the newest version :
            ov-02 4:38:08 PM JowiHue Warning: Sensor with reference 1838 will be converted later
            Nov-02 4:38:08 PM JowiHue Warning: Sensor with reference 1836 will be converted later
            Nov-02 4:38:07 PM JowiHue Warning: Sensor with reference 1835 will be converted later
            Nov-02 4:38:07 PM JowiHue Warning: Sensor with reference 1824 will be converted later
            Nov-02 4:38:07 PM JowiHue Warning: Sensor with reference 1822 will be converted later
            Nov-02 4:38:07 PM JowiHue Warning: Sensor with reference 1821 will be converted later
            Nov-02 4:38:03 PM JowiHue Error: (UpgradeDevice):Object reference not set to an instance of an object.
            Nov-02 4:38:03 PM JowiHue Error during conversion for deviceref 1666 0
            Nov-02 4:38:03 PM JowiHue Error during conversion for deviceref 1662 0
            Nov-02 4:38:02 PM JowiHue Error: (UpgradeDevice):Object reference not set to an instance of an object.
            Nov-02 4:38:02 PM JowiHue Error during conversion for deviceref 1658 0
            Nov-02 4:38:02 PM JowiHue Error during conversion for deviceref 1654 0
            Nov-02 4:38:01 PM JowiHue Error: (UpgradeDevice):Object reference not set to an instance of an object.
            Nov-02 4:38:01 PM JowiHue Error during conversion for deviceref 1650 0
            Nov-02 4:38:01 PM JowiHue Error during conversion for deviceref 1646 0
            Nov-02 4:38:01 PM JowiHue Error during conversion for deviceref 1642 0
            Nov-02 4:38:00 PM JowiHue Error: (UpgradeDevice):Object reference not set to an instance of an object.
            Nov-02 4:38:00 PM JowiHue Error during conversion for deviceref 1638 0
            Nov-02 4:38:00 PM JowiHue Warning: Sensor with reference 1637 will be converted later
            Nov-02 4:38:00 PM JowiHue Warning: Sensor with reference 1635 will be converted later
            Nov-02 4:38:00 PM JowiHue Warning: Sensor with reference 1634 will be converted later
            Nov-02 4:38:00 PM JowiHue Warning: Sensor with reference 1633 will be converted later
            Nov-02 4:37:59 PM JowiHue Warning: Sensor with reference 1631 will be converted later
            Nov-02 4:37:59 PM JowiHue Warning: Sensor with reference 1630 will be converted later
            Nov-02 4:37:59 PM JowiHue Warning: Sensor with reference 1629 will be converted later
            Nov-02 4:37:59 PM JowiHue Warning: Sensor with reference 1627 will be converted later
            Nov-02 4:37:59 PM JowiHue Warning: Sensor with reference 1626 will be converted later
            Nov-02 4:37:59 PM JowiHue Upgrading devices to latest version 10
            Nov-02 4:37:58 PM JowiHue Bridge device Indianapolis Hom not containing a valid IP address, was it reset?
            Nov-02 4:37:58 PM JowiHue Warning: warning! Missing ipaddress in device for bridge Indianapolis Hom, wil try repair
            Nov-02 4:37:55 PM Plug-In Finished initializing plug-in JowiHue
            Nov-02 4:37:55 PM JowiHue Importing lamp and sensor Types
            Nov-02 4:37:55 PM JowiHue InitIO:Plugin basic initialisation done
            Nov-02 4:37:55 PM JowiHue ****** Creating table SensorTypes
            Nov-02 4:37:55 PM JowiHue ****** Creating table LampTypes
            Nov-02 4:37:55 PM JowiHue Starting plugin JowiHue 2.0.1.1 on Windows
            Nov-02 4:37:55 PM JowiHue Upgrading database to version 4
            Nov-02 4:37:55 PM Info Plugin JowiHue has connected. IP:127.0.0.1:62049
              Same Here
              I am having the same error. i cant even manually turn the light on or off from HS3 the plugin stops and then restarts.
                Invalid URI:
                Having the same issue, started with the last update
                  I did as well. Updated the plugin because of the URI-error, lots of errors in the log. Then restarted the plugin once more and all was well.
                    All,
                    The uri error seems to come from Philips for some reason, don't know yet what is happening. I have altered the plugin so it will not go to the philips site if the internal UPNP call is working normally. Only if it is not working, it will go to the meethue site for an alternate test. But then the plugin might still report this issue. For most this will not happen any more. This should stop the every 5 minute log error on the URI.
                    I have not been able to copy the issue of restarting the plugin. This should only happen if internal memory of the plugin is damaged. It was there already for some time during beta of version 2, so I am surprised seeing it is happening here. Could not copy the issue, so I have removed the restart and maybe you will see some error in the log using this version. Be sure to let me know what error it is?
                    The new version is avalable in the manage plugins area
                    Wim
                    Last edited by w.vuyk; November 3rd, 2017, 05:52 PM. Reason: JowiHue version 2.0.1.2 is published
                    -- Wim
                      Still issues ?
                      I get the following output from debug, I'm unable to find the bridge at all (Android app found it without any problem) This is on a Win 64 bit server. The log shows first entry with access to the Internet, the second Internet access is blocked. Then I don't get the URI message. This with the 2.0.1.2 version.
                      (web_config.postBackProc) Debug: Config:File: checked
                      (web_config.postBackProc) Debug: Config:id: File
                      19.34.02.3192918 -- (web_config.postBackProc) Debug: Config:Trace: checked
                      19.34.02.3192918 -- (web_config.postBackProc) Debug: Config:id: Trace
                      19.34.24.7796317 -- (web_config.postBackProc) Debug: oTabConfig
                      19.34.24.7796317 -- (web_config.postBackProc) Debug: ConfigTabs: oTabConfig
                      19.34.24.7836559 -- (web_config.postBackProc) Debug: Config:id: oTabConfig
                      19.34.26.0587947 -- (web_config.postBackProc) Pressed button for immediate scan for bridges - scanning started
                      19.34.26.0587947 -- (UPNP.Bridgescan) Debug: Start Scan for bridges 03.11.2017 19.34.26
                      19.34.26.0587947 -- (web_config.postBackProc) Debug: Config:id: obtnScan
                      19.34.26.0627952 -- (web_config.postBackProc) Debug: Config:btnScan: Submit
                      19.34.29.0716503 -- (web_config.postBackProc) Debug: Config:id: timer
                      19.34.32.0794536 -- (web_config.postBackProc) Debug: Config:id: timer
                      19.34.56.0625691 -- (UPNP.UDPListener) 3 blocks found to process
                      19.34.56.2522765 -- (UPNP.Bridgescan) UPNP checkmeethue [{"id":"001788fffe28c5fd","internalipaddress":"192.168.200.20 "}]
                      19.34.56.2522765 -- (UPNP.Bridgescan) Unknown Bridge found on IP 192.168.200.20
                      19.34.56.2522765 -- (UPNP.Bridgescan) Error: Invalid URI: The hostname could not be parsed.
                      19.34.56.2762533 -- (UPNP.Bridgescan) stap 1.2 meethue done ---- System.UriFormatException(0x80131537): Invalid URI: The hostname could not be parsed.
                      at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
                      at System.Uri..ctor(String uriString)
                      at HSPI_JowiHue.BridgeApi.GetJsonCommand(String URL, Object ReqObject, Boolean Dict, String Type)
                      at HSPI_JowiHue.MyBridges.BridgeFound(String BridgeIP, String Port)
                      at HSPI_JowiHue.UPNP.Bridgescan()
                      19.34.56.2762533 -- (UPNP.Bridgescan) Debug: End search for bridges
                      19.35.17.8416168 -- (HueTools.MainWatchTimer) Debug: Checking plugin health 03.11.2017 19.35.17
                      19.37.17.8499006 -- (HueTools.MainWatchTimer) Debug: Checking plugin health 03.11.2017 19.37.17
                      19.39.17.8570417 -- (HueTools.MainWatchTimer) Debug: Checking plugin health 03.11.2017 19.39.17
                      19.39.26.0628141 -- (UPNP.Bridgescan) Debug: Start Scan for bridges 03.11.2017 19.39.26
                      19.39.56.0679926 -- (UPNP.UDPListener) 3 blocks found to process
                      19.40.01.6686632 -- (web_config.BuildContent) A. Starting buildcontent
                      19.40.01.6686632 -- (web_config.BuildMiscellaneousOptions) F. build Miscellaneous options
                      19.40.01.6686632 -- (web_config.BuildMiscellaneousOptions) G. checking luminaires and dimmmerswitches
                      19.40.05.1416711 -- (web_config.postBackProc) Debug: Config:id: timer
                      19.40.05.3416886 -- (UPNP.Bridgescan) Bridgescan already running, quiting this scan
                      19.40.05.3416886 -- (web_config.postBackProc) Pressed button for immediate scan for bridges - scanning started
                      19.40.05.3456890 -- (web_config.postBackProc) Debug: Config:id: obtnScan
                      19.40.05.3456890 -- (web_config.postBackProc) Debug: Config:btnScan: Submit
                      19.40.07.1825734 -- (UPNP.Bridgescan) UPNP scan aborted - incomplete response from bridge
                      19.40.07.1825734 -- (UPNP.Bridgescan) Debug: End search for bridges
                      19.40.08.3546522 -- (web_config.postBackProc) Debug: Config:id: timer
                      19.40.11.3628303 -- (web_config.postBackProc) Debug: Config:id: timer
                      19.41.17.8653526 -- (HueTools.MainWatchTimer) Debug: Checking plugin health 03.11.2017 19.41.17
                        I updated to version 2.0.1.2 of the plugin. I am still getting the Bridgescan Error, although not as frequently.
                          Wim,
                          Here the same. Updated the plugin to 2012 and also restarted HS3.
                          Updated in Homeseer, not with replacing the file.
                          The frequent is also the same , every 5 minutes.
                          In this post i read something about Upnp ; (System is Discoverable Using UPNP), do we have to disable this in Homeseer?
                          nov-04 0:43:34 JowiHue Error: (Bridgescan):Ongeldige URI: de hostnaam kan niet worden geparseerd.
                          nov-04 0:38:34 JowiHue Error: (Bridgescan):Ongeldige URI: de hostnaam kan niet worden geparseerd.
                          nov-04 0:33:34 JowiHue Error: (Bridgescan):Ongeldige URI: de hostnaam kan niet worden geparseerd.
                          nov-04 0:28:34 JowiHue Error: (Bridgescan):Ongeldige URI: de hostnaam kan niet worden geparseerd.
                          nov-04 0:23:34 JowiHue Error: (Bridgescan):Ongeldige URI: de hostnaam kan niet worden geparseerd.
                          nov-04 0:18:34 JowiHue Error: (Bridgescan):Ongeldige URI: de hostnaam kan niet worden geparseerd.
                          nov-04 0:13:34 JowiHue Error: (Bridgescan):Ongeldige URI: de hostnaam kan niet worden geparseerd.
                          Etc,etc
                          Egbert
                            The error will stay when the internal UPNP call does not work, I am still hoping that I discover what the Philips site changed to make the plugins call error. But I have no clue yet.
                            So if your internal UPNP call works (is router set correctly to enable UPNP, is the windows firwall allowing the plugin to do calls etc.) the call to the meethue site is skipped, otherwise it will do the call and the error stays.
                            It does not cripple the plugin in its function normally.
                            Wim
                            -- Wim
                              Wim,
                              On my HS3 windows 10 OS, Upnp was not activated, never used it??
                              So i enabled it by turning on the network discovery.
                              The error is now gone, for now the 5min interval messages are gone.
                              Egbert
