(Bridgescan):Invalid URI: The hostname could not be parsed.
  • #16
    Egbert,
    Thanks for confirming. The plugin needs the upnp to discover local bridge, the meethue site is used as a backdoor if local searches fails. If you’d have plugins like Sonos or mediacontroller you would have had similar issues too.
    I still will keep an eye on why this happens... been searching but find no clues yet on why the site is responding different now. Don’t know if I could do the same request differently in the plugin...
    Wim
    -- Wim
    • #17
      For those having the restarts and that have moved to version 2.0.1.2 of the plugin, how are the restarts now? Are they gone - any errors in the log?
      Wim
      -- Wim
      • #18
        I am not seeing any plugin restarts with 2.0.1.2. I don’t enable UPNP on my router, so unfortunately I will have to get all the Bridgescan errors in the log.
        • #19
          On 2.0.1.2, for me, the error is almost gone.
          I filtered the log for JowiHue, this is what I found for the last 24 hours (since the last restart of the plugin):
          Nov-04 14:45:08 JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
          Nov-03 23:05:07 JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
          Nov-03 21:55:07 JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
          Nov-03 16:20:07 JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
          Nov-03 15:50:07 JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
          Nov-03 15:04:23 JowiHue Error: (UpdateUsage):Concurrency violation: the UpdateCommand affected 0 of the expected 1 records.
          Nov-03 14:49:40 JowiHue Plugin succesfully started
          The plugin is fully functional.
          • #20
            Interesting - I have gotten about 50 of the errors in 12 hours since I restarted the plugin.
            • #21
              I think that for akkie71 the UPNP call misses every now and then. That can happen when you stream a lot on the network. I stream 4K movies ove my network, that can put a burdon on the response of other trafic as streaming is a high priority traffic. Not necessarry something to worry about, but it could explain the difference.
              But I come with good news
              I have found a good alternative that solves the issue. I am running it here now with the old setting - always calling meethue and there are no more issues!
              Few more changes are in the plugin that I want to test, somewhere next week I will post the new version to the updater
              Wim
              -- Wim
              • #22
                This fixed yet?
                Jan-11 8:48:05 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
                I have 3000 log entries in 3 days!
                Jim
                Plugins:Z Wave 3.0.1.55, HS3 Pro 3.0.0.208, HS3Touch, HS3Touch IOS, Z-Net, SceneMaster, XBMC, Sonos, Media Controller, Envisalink (52 Virtual nodes), JowiHue, EasyTrigger, Liftmaster MyQ, BLBackup, BLLAN, BLRadar, Pushover
                Devices:Cooper RF9540, Cooper Scene, Yale Locks, Sonos, Phillips Hue and Lux, DSC, Somfy Blinds
                • #23
                  Jim,
                  Which version are you running? This should have been resolved with the current version 2.0.1.6?
                  Wim
                  -- Wim
                  • #24
                    yes - it is now gone - my bad - i though i had updated, but hadn't
                    Jim
