Me again
  • Me again
    Hey Jowi,
    I dont know whats going on now but ever since i upgraded to the latest version of the plugin i keep getting this error. It happends when i try to manually turn a device off or on. Also now that i have registered HS3 i get this error. 2 problems listed below 2 different logs.
    Nov-02 8:58:11 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
    Nov-02 8:53:11 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
    Nov-02 8:48:11 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
    Nov-02 8:43:11 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
    Nov-02 8:38:11 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
    Nov-02 8:33:21 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
    Nov-02 8:28:11 AM JowiHue Error: (Bridgescan):Invalid URI: The hostname could not be parsed.
    ____________________________________________________________ __
    JowiHue Plugin succesfully started
    Nov-02 6:52:42 AM JowiHue 3 Animations available for use in this plugin
    Nov-02 6:52:42 AM JowiHue Device of reporting bridge and light firmware updates is enabled
    Nov-02 6:52:42 AM JowiHue ============================================================ ==================================
    Nov-02 6:52:42 AM JowiHue 15 Local scenes available for use in the JowiHue plugin
    Nov-02 6:52:42 AM JowiHue 1 Daylight sensor found on bridge 'Philips hue'
    Nov-02 6:52:42 AM JowiHue 1 Generic status sensor found on bridge 'Philips hue'
    Nov-02 6:52:42 AM JowiHue -------------------------------------Plugin info ---------------------------------------------
    Nov-02 6:52:42 AM JowiHue 22 Presets available for use in the JowiHue plugin
    Nov-02 6:52:42 AM JowiHue 1 Presence sensor found on bridge 'Philips hue'
    Nov-02 6:52:42 AM JowiHue -------------------------------------Bridge info ---------------------------------------------
    Nov-02 6:52:42 AM JowiHue 6 lights connected to bridge 'Philips hue'
    Nov-02 6:52:42 AM JowiHue 11 Groups available on bridge 'Philips hue'
    Nov-02 6:52:41 AM JowiHue * Connected to bridge Philips hue at 10.0.0.174
    Nov-02 6:52:40 AM JowiHue InitIO:Plugin basic initialisation done
    Nov-02 6:52:40 AM JowiHue Starting plugin JowiHue 2.0.1.1 on Windows
    Nov-02 6:51:53 AM JowiHue Error: (SetDeviceByUserRequest):An unrecoverable issue with the internal datatables has occurred! The plugin will shutdown
    Tim,
    Check this thread: https://forums.homeseer.com/showthread.php?t=191727
    I think there is a change on the meethue site of Philips here...
    Wim
    -- Wim
      More
      Ok ill check that link, but what about that other problem.
      It shutsdown the plugin it does restart but i can turn the light on or off from the HS web page.
      Here what i get when i try to turn a device on or off manually
        How often do you get that message? It can occur sometimes. It triggers when the internal memory for the plugin is compromised for some reason - memory full, other programs, bad memory lost of that.
        The plugin restarts then to be sure it can continue. You should be able to control the lights and all, except during that restart?
        Wim
        -- Wim
          All thee time
          This happens every time I try to turn the light on or off via the Homeseer webpage. The device never turns on or off and I can’t control it manually.
          Also I was thinking of maybe starting over from scratch with this plugin again now that hs3 is registered and I’m purchasing yours today. What would be the best way to just start over.
            I am here checking why this restart routine is triggering, it does not happen here.
            I would wait a bit with starting all over for now?
            Wim
            -- Wim
              Tim,
              Please check this thread for an update: https://forums.homeseer.com/showthread.php?t=191727
              Wim
              -- Wim
