Ikea bulb On/Off does not go to Last state.
  • Ikea bulb On/Off does not go to Last state.
    I have some trouble with all my Ikea bulbs. The on/off function does not take the light level back to the last state. It just go off/max level.
    I use ConBee with the DeCONZ gateway. The on/off function in the DeCONZ webinterface does go to the last state when toogle the power buttons.
    I have a new installation, so i dont know if it has been working before.
    My DeCONZ version is 2.04.82.
    Current Date/Time: 02-11-2017 20:41:51
    HomeSeer Version: HS3 Pro Edition 3.0.0.368
    System Uptime: 0 Days 1 Hour 35 Minutes 44 Seconds
    IP Address: 192.168.1.10
    Number of Devices: 295
    Number of Events: 33
    Available Threads: 400
    Enabled Plug-Ins
    3.0.0.37: EasyTrigger
    3.6.5.0: Harmony Hub
    2.0.1.1: JowiHue
    3.0.1.8: Kodi
    3.0.0.21: Sonos
    3.0.6159.37431: UltraNetatmo3
    3.0.6175.15900: UltraNetatmoWelcome3
    3.0.1.130: Z-Wave
    Idplusse,
    Will check on it and see if I could work differently for the Ikea bulbs. Those respons diffently from the philips bulbs it seems.
    Wim
    -- Wim
      Idplusse,
      Wim
      Would be great.
      I have the Ikea GU10, and the E14 (400lm) bulbs.
      i can confirm that those 2 have the problem, when using DeCONZ.
      But in DeCONZ Web interface the on/off function does remember the last state.
      Any help i could provide, you just ask and i will jump in
        Lars,
        Great news for the deCONZ part - I have updated the way the on command is send for the deCONZ and the old setting will come active! That means that simply send the on to the raspbee or conbee will switch the light on in the setting it was before being switched off.
        This still will not solve it for Philips Hue bridges
        It will be in the next release - hope to send it out next week
        Wim
        -- Wim
          Lars,
          Wim
          That is super.
          Then looking forward to a workaround for the dim up/down.
            DeCONZ light should go back to original level when switched on after an off now. Versione 2.0.1.3 is published
            Wim
            -- Wim
              I get a new error every 30 seconds after updating to 2.0.1.3.
              JowiHue Error: (UpdateGroups):Object variable or With block variable not set.
              Regards
              Morten
                Wim
                Super.
                And it is confirmed working for me.
                I dont get any errors in my logs like Morten do.
