Xiaomi devices
  • Xiaomi devices
    Hello
    https://www.gearbest.com/access-control/pp_626703.html
    Give:
    16:16:25.4780396 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"2","r":"sensors","state":{"lastupdated" :"2017-11-29T15:16:24","open":true},"t":"event"} new queue size is 0 on 00212EFFFF013778
    16:16:25.4780396 -- (MySensors.UpdateSensor) Error Cannot check OpenClose 2 as there is no capabilities known (yet) for this sensor (ZHAOpenClose). This might indicatie the plugin is not yet fully initialised
    And no device in Jowi
    Regards
    Hello
    https://www.aliexpress.com/item/Orig...801172560.html
    Give:
    16:07:20.3441801 -- (MySensors.InititialSensors) Added deCONZ Sensor lumi.sensor_switch 8 of type ZHASwitch
    1002 when one short press
    1002 when press and hold down for ever.
    2002 when two short press
    3002 when three short press
    4002 when four short press
    Nothing at five or more presses.
      Hello
      https://www.gearbest.com/access-control/pp_626695.html
      Give
      16:07:44.4539093 -- (MySensors.UpdateSensor) UpdateSensor... updated Switch 9 type ZHASwitch To 1002
      16:07:44.4539093 -- (MySensors.UpdateSensor) UpdateSensors button pressed Switch 9 button value 1002
      No change when pressing the button.
        Jan,
        you are busy with many new devices
        I will add the known values to the plugin and name the devices, so the actions done are showing more logical descriptions.
        As for the window sensor, indeed still unknown to the plugin... will have to do some extra codiing for that. There are also other requests waiting for other sensortypes.
        First here trying to solve the double devices issue for conbee, so it might take a bit....
        Thanks!
        Wim
        -- Wim
          Hi
          I have edited the post about https://www.aliexpress.com/item/Orig...801172560.html
          https://forums.homeseer.com/showpost...72&postcount=2
            Jan,
            Once I start on these sensors it will be a large change as I will try to make the sensor configuration more 'dynamic' in a sense that I can configure a sensor without updating code in the plugin as I think/am afraid many new sensors will come. This will be a major update of course.
            One of the things I will need is the modelid of the sensors. For those sensors that have created a device you can find the modelid in the properties of the device, on the JowiHue tab. For the sensors that did not yet create a device in the plugin, you need to place the attached INI file in the config directory of yur HS installation. The plugin will check on this file every 15 minutes or so. Once the plugin has read the file (should have done then in 15 minutes or so) You will see a "dump" button apear in the configuration page behind every bridge. For the bridge holding the new sensor, press the button.
            A log file will be created in the logs directory then, holding all bridge information. You can send me this log (limited to the sensors part if you want)
            I then can get the needed static details from this log.
            Thanks!
            Wim
            PS make sure to rename the .txt file to .ini!
            -- Wim
              Hi Wim
              Done and mail posted to you.
              /Jan
                Hi Wim
                Some news?
                /Jan
                  Jan,
                  Not yet. Am working on the cchange here, but time is not my friend at the moment. It is a complex change as I want the plugin to be prepared for future sensors with this change too.
                  I do not think it will be ready before Christmas yet here.
                  Wim
                  -- Wim
                    I have the Xiaomi temperature and humidity sensor (http://s.aliexpress.com/iY3ABZNf), works well in deCONZ and JowiHue creates two devices, but with value 0 (never updated).
                    Type: ZHASwitch
                    Model: lumi.sensor_ht
                    I guess these also will be supported later on?
                    Great work on the plugin, btw!
                      Type: ZHASwitch
                      I have the same device, but it most be different. it shows in DeCONZ but not in JowiHue.
                      But the model is also reporting as lumi.sensor_ht
                      I use ConBee and DeConz .97 (The same on .86)
                        I have several reports of new devices either reporting 0 or not showing in the plugin. I am guessing this is depending on the deCONZ version running or maybe even which beta's of deCONZ have been active on the device.
                        As for the temperature and humidity devices I am very sure the plugin is not equiped yet to support those. Also Osram motion sensor seems to support the temperature, but until now only the Hue motion sensor is supported. Will add all of them.
                        On itself, per device, it is an easy task, but I am trying to get an "open" interface, so I will not have to update the plugin on every new sensor. Instead I want to be able to deliver a file that updates the (could be endless) list of sensors available. Bear with me, I am working hard on this, thinking on how to is the worst part of this update
                        I guess once I have a solution, a new beta of the plugin will arise
                        Wim
                        -- Wim
                          Will be looking forward to the Beta.
                          So sign me up for testing.
                          Sent from my iPhone using Tapatalk Pro
                            Strange. It showed up as a device in HS immediately for me.
                            Sounds good!
                            Totally understand the need for "restructuring" the code, so that adding new device is easier in the future. I see both here and on the deCONZ Github that there are many requests for new devices - must be because you and de deCONZ-people have made a great product!
                              Hi Wim, Hi everyone,
                              Happy new year.
                              This is great news, can't wait for this beta
                              I suppose Aqara Wall Switch will be supported then... ? The one without wire already works aproximatively, but the wired one, although recognized in the deCONZ graphical interface, doesn't appear anywhere else (not in the webapp, not in the Phoscon app, not in Jowihue).
                              Michel
