HowTo add DeCONZ compatible devices to deCONZ
This is a sticky topic.
    A small compatibility list for devices that work with DeCONZ and JowiHue plugin and how they operate, what devices to see etc.
    There should be some info to fill for what info i desirable.
    1) Device Name: Xiaomi Aqara Switch
    2) Device manufactor link: https://www.aqara.com/cn/wireless_switch.html
    3) How to add to HS: Push jowihue 'Scan for new sensors' and the push button on remote for 5 sec. it starts to blink blue.
    4) What devices to see in HS: 1 device called: lumi.sensor_switch.aq2
    5) Status from devices: single, double, triple & quad clicks
    5) Devices that could be missing in HS: Battery status, The Shake sensor.
    6) How to add additional features: Dont know.
    7) How well is it working: Works very well.
    8) Build quality: Very good.
    9) What DeCONZ versions have been tested: 2.04.86
    1) Device Name: Xiaomi Aqara Mi Cube (Magic Cube)
    2) Device manufactor link: https://www.aliexpress.com
    3) How to add to HS: Push jowihue 'Scan for new sensors' and the push button on Mi Cube for 5 sec. it starts to blink blue. Keep flipping, twisting shakeing for 2 minutes.
    4) What devices to see in HS: 2 devices called: Switch x
    5) Status from devices: Flip, rotate, push, dobbelt tap, shake.
    5) Devices that could be missing in HS: Battery status.
    9) What DeCONZ versions have been tested: Added with 2.04.86
    1) Device Name: Xiaomi Aqara Smart Windows/Door Sensor
    3) How to add to HS: Push jowihue 'Scan for new sensors' and the push button on Sensor for 5 sec. it starts to blink blue.
    4) What devices to see in HS: 1. Open/Close.
    5) Status from devices: Open/Close.
    7) How well is it working: Dont know yet.
    1) Device Name: Xiaomi Aqara light & motion sensor ("human body sensor")
    2) Device manufactor link: https://www.gearbest.com/alarm-systems/pp_659226.html
    3) How to add to HS: Push jowihue 'Scan for new sensors' and the push button on Sensor for 5 sec. it starts to blink blue. (also ok with Webapp).
    4) What devices to see in HS: Motion ON-OFF, battery level (%)
    5) Devices that could be missing in HS: Lightlevel is accessible in Phoscon/deCONZ, but NOT in HS
    6) How to add additional features: see link
    7) How well is it working: good
    9) What DeCONZ versions have been tested: Added with 2.04.99
    1) Device Name: Xiaomi Aqara Temperature Sensor (The one without Pressure)
    4) What devices to see in HS: 2. Temperature, Humidity
    5) Status from devices: Degree and Humidity values
    7) How well is it working: Very good. updates often
    1) Device Name: Xiaomi Smoke sensor (brand name on device is Honeywell)
    2) Device manufactor link: https://www.gearbest.com/alarm-systems/pp_615081.html
    Push jowihue 'Scan for new sensors' and the push button on smoke sensor for 5 sec. The siren will sound and a short orange blink will show on the device
    4) What devices to see in HS: 1 device with modelid lumi.sensor_smoke, named “Fire nn” where nn is the internal ID
    5) Status from devices: True or false for fire
    2.05.10
    Do you have devices that is missing on this list, then copy my 9 lines and make a new post, i will update this main post.
    Hello Idplusse, hi everyone,
    I just received this. Great.
    6) How to add additional features: see below a link
    See here (in french) :
    http://domotauks.fr/index.php/2017/0...n-body-sensor/
    Seems that time of motion could be detectable. But in HS, only can see that sensor is blocked ON for 1 minute when movement is detected, and its a bit ennoying (like Ikea Tradfri).
      Door/windows sensor indeed doesn't appear in HS.
      But in Phoscon webapp, it's there, and very very reactive (could think there's a wire).
        I also see my Door/Windows Sensor and the Temperature sensor in Phoscon, but not in HS.
        Wim is coding like crazy to give us support for these devices.
          Here it's a bit different : I do see temperature Jowihue device from temperature sensor in HS, but this sensor gives two more parameters in Phoscon app : humidity and air pressure. Humidity gives a correct value, Air pressure doesn't (showing zero and we are not in space, as far as I know).
          So, is the folowing deduction correct ? Jowihue will maybe me able to get humidity and pressure, while deCONZ is already OK for humidity, but still buggy for pressure ?
          Anyway, this very little sensor seems to be really great with temperature, humidity and pressure indications.
            I will be releasing a new beta next week, that should include the weather sensor of Xiaomi. I have some doubts on the pressure device as the info I got from you all, the pressure was 0 for all... I doubt that deCONZ puts the correct value on the REST API. We will see
            Wim
            -- Wim
              Hey Wim,
              Very glad to read this !
              Happy new year !
              Mich
                I have just added my Xiaomi Aqara Mi Cube and I can see two devices but the rotation device is always zero degrees. Rotating the cube updates the date modified but rotation remains as 0.
                Steve
                  Steve
                  I have the same problem.
                  I guess you have your DeCONZ on windows, because that is where we found the error.
                  The guys are going to release a new DeCONZ version this week, where the rotation on Windows DeCONZ should be fixed.
                  So stay tuned for that release.
                    Thanks for that and yes I can confirm I am on Window.
                    steve
                      Same issue here, Windows too.
                      Great news for deCONZ new version.
                        That now works perfectly with the new version.
                        Steve
                          I have just successfully added
                          1) Device Name: Xiaomi Aqara Wireless Switch
                          2) Device manufactor link: https://m.banggood.com/Original-Xiao...l?rmmds=search
                          5) Status from devices: single, double, triple & quad clicks Note values returned are different to expected one press is 1002, two presses is 1004, three presses is 1005, four presses is 1006
                          9) What DeCONZ versions have been tested: 2.04.99
                            I have this switch and a couple of other Xiaomi zigbee devices on order.
                            I'm curious if you were to hold the button for a few seconds and then release, if that would yield 1003 "button released", or perhaps some other code.
                            That's how it is for my ZRC-90 which of course has nothing to do with these devices, but you never know.
                              Just tried and a value of 1000 is returned whilst the button is held followed by 1002 when it is released.
                              Steve
