HowTo add DeCONZ compatible devices to deCONZ
This is a sticky topic.
  • #76
    Wim - Wow, you're good. Those steps worked like a charm and I was able to see the devices in less than 30 secs. Thanks for help. Now it's time to order some more sensors...
    • #77
      I must be missing something....I cannot get philips hue light bulbs to be discovered in Deconz even thru using the old webapp...using conbee II...
      • #78
        I could help better when you describe the steps you did trying to connect the lights? Now it is a bit of a guessing game to find what step(s) you might have missed?
        Here are some things to look at....
        • Are you running on Windows or Linux?
        • What do you see in the interface of deCONZ?
        • Is the bridge added as device in HomeSeer?
        • When you start a search through the configuration page of the plugin, do you see reponse in the deCONZ interface? (blinking dots, new devices added)
        • Have the Hue lights been used before? Make sure they are reset otherwise they willl not be discovered at all
        • When you start discovery of lights, make sure the Philips Hue lights have been powered off just before that
        Wim
        -- Wim
        • #79
          thanks for the response...and apologies for the lack of info:
          Win10
          What I see in interface is attached...
          I have not added the bridge as a device in homeseer yet because I haven't been able to find anything in Deconz
          No new devices added when I do a search
          Hue lights have been used before -currently talking to the hue bridge
          i just tried to discover with the power off and powering on to no avail.
          Thanks in advance for your help...
          • #80
            You will have to reset the bulbs first before you can add the bulbs to deCONZ. They will only connect to one coordinator, which is the Hue bridge now?
            -- Wim
            • #81
              Are these Xiaomi devices available for UK-Europe frequency?
              • #82
                There are no differences in frequecy, so you are save checking for sensors. I have the same water sensors here
                -- Wim
                • #83
                  Great! Thanks!!
                  • #84
                    1) Device Name: Xiaomi Aqara Motion Sensor (RTCGQ11LM)
                    2) Device manufactor link: https://www.aqara.com/eu/motion_sensor.html
                    3) How to add to HS:
                    4) What devices to see in HS: 4 device called: lightlevel, battery, lux, motion
                    5) Status from devices: motion, lux, battery
                    5) Devices that could be missing in HS: Temperature
                    6) How to add additional features: Dont know.
                    7) How well is it working: Works very well.
                    8) Build quality: Very good.
                    9) What DeCONZ versions have been tested: 2.0xx (should be latest, will check later today)
                    1) Device Name: Xiaomi Aqara Vibration Sensor (DJT11LM)
                    2) Device manufactor link: https://www.aqara.com/eu/vibration_sensor.html
                    4) What devices to see in HS: 9 device called: Root, Battery, Orientation X, O-Y, O-Z, Positon, Tilt Angle, Vibration, Vibration Strength
                    5) Status from devices: Battery, O-X,Y,Z, Tilt Angle, Vibration and Vibration Strength
                    Sensors added in deCONZ, temperature shows up in deCONZ, but not in HS3/Jowihue.
