Error when running animation
  • Error when running animation
    HomeSeer Version: HS3 Standard Edition 3.0.0.368
    2.0.1.6: JowiHue
    deCONZ 2.04.97
    IKEA Tradfri RGB-bulb
    Scenes:
    Animation:
    When running the animation, these errors appear every 1 minute:
    Dec-16 13:27:49 JowiHue Error: (HandleWebQueue):Only the field value can be specified to set a field value. Parameter name: bindingFlags
    Dec-16 13:27:49 JowiHue Start of animation Utelys - jul
    The animation seems to be working fine.
    Any ideas?
    Zorac,
    The message you are seeing seems to be a reply from the deCONZ gateway, which throws an error on the plugin. Guessing there is a reply that was not expected or net yet known by the plugin.
    Will need a bit more info. Which version deCONZ are you on?
    And could you do a detailed trace to file for me, catching that error? You have my email address I believe?
    Wim
    -- Wim
