"Group All Lights" and other not populated
  • "Group All Lights" and other not populated
    I have just installed the JowiHue plugin and when exploring the settings I noticed that several of the settings in the Bridge Maintenance page are not populated. For example:
    #1. the Lights on the Bridge shows two lights that are member of the All Lights and Woonkamer group, but when expanding the Group All Lights not lights are listed. Looking at the manual page 17/56 I believe it should list all lights.
    #2. Scenes on the Bridge says its holding 9 scenes but when expanding the item no scenes are shown.
    The Plugin itself is working, I can control lights from HS3 and status is updated in HS3 if lights are changed using the remote control.
    Francois,
    Are there errorlines in the log when you open the all groups or scenes on the bridge maintenance page? Maybe I missed some special characters in the name? Had updated this for both. Here I am not using special characters and everything opens normally.
    Are you using the Philips bridge or one of the gateways?
    Wim
    -- Wim
      Weird....I posted a reply this morning but for some reason it disappeared from the board. Re posting
      wIM,
      I am using the Philips bridge from the color ambiance starter pack. Looking at the log I noticed several error messages related to expanding the groups or scenes, please find the log below:
      dec-19 10:31:24 JowiHue Error: (BuildSliderBridgeScenes):web Maintenance:Object reference not set to an instance of an object.
      dec-19 10:31:14 JowiHue Error: (BuildSliderGroupDetail):web Maintenance group:Object reference not set to an instance of an object.
      dec-19 10:22:52 JowiHue Error: (BuildSliderGroupDetail):web Maintenance group:Object reference not set to an instance of an object.
      dec-19 10:21:45 JowiHue -------------------------------------Plugin info ---------------------------------------------
      dec-19 10:21:45 JowiHue 22 Presets available for use in the JowiHue plugin
      dec-19 10:21:45 JowiHue 6 Local scenes available for use in the JowiHue plugin
      dec-19 10:21:45 JowiHue 2 Animations available for use in this plugin
      dec-19 10:21:45 JowiHue Device of reporting bridge and light firmware updates is enabled
      dec-19 10:21:45 JowiHue ============================================================ ==================================
      dec-19 10:21:45 JowiHue Plugin succesfully started
      dec-19 10:21:45 JowiHue 2 lights connected to bridge 'vanHemert'
      dec-19 10:21:45 JowiHue 2 Groups available on bridge 'vanHemert'
      dec-19 10:21:45 JowiHue Bridge vanHemert is at version 1711151408 of type BSB002
      dec-19 10:21:45 JowiHue 1 Remote switch(s) found on bridge 'vanHemert' with 1 supporting HS device(s)
      dec-19 10:21:45 JowiHue 1 Daylight sensor found on bridge 'vanHemert'
      dec-19 10:21:45 JowiHue 1 Generic flag sensor found on bridge 'vanHemert'
      dec-19 10:21:45 JowiHue 1 Generic status sensor found on bridge 'vanHemert'
      dec-19 10:21:45 JowiHue -------------------------------------Bridge info ---------------------------------------------
      dec-19 10:21:44 JowiHue * Connected to bridge vanHemert at 192.168.1.109:80
      dec-19 10:21:42 JowiHue InitIO:Plugin basic initialisation done
      dec-19 10:21:42 JowiHue Starting plugin JowiHue 2.0.1.6 on Windows
        Franco s,
        Could you do a detailed trace to log for me while opening the maintenance page and opening groups and scenes? Mail me the log, hoping I can get some more info out of it. Any special characters in the names of the lights and/or scenes?
        Wim
        -- Wim
          Will do as soon as I have my internet connection back
            Ouch... Christmas without internet might be a challenge nowadays
            Wim
            -- Wim
              Well it only took a day and I am back again....so Christmas will be quiet and peaceful
              I just created the logfile using the following steps:
              • Start the plugin
              • Open PI Bridge Plugin maintenance
              • Expand Groups
              • Expand Group all lights --> shows nothing
              • Expand Group Woonkamer --> Shows two lights that are currently configured
              • Expand Scenes(20) --> no content shown
              • Stop the plugin
              Hope you can find what is going on.
              08:18:04.5922280 -- (plugin.InitIO) Starting plugin JowiHue 2.0.1.6 on Windows
              08:18:04.6078560 -- (plugin.InitIO) ===================== start plugin at 22-12-2017 08:18:04 ========================
              08:18:04.6078560 -- (plugin.InitIO) Debug: Database location Data Source=C:\Program Files (x86)\HomeSeer HS3/Data/JowiHue/JowiHue.db;Version=3;Pooling=True;Max Pool Size=100;
              08:18:04.6078560 -- (SQLiteFunctions.InitDatabase) starting
              08:18:04.6234814 -- (SQLiteFunctions.InitDatabase) Usage table contains 2 rows
              SQLite error (1): duplicate column name: BrightEnabled
              08:18:04.6391062 -- (SQLiteFunctions.InitDatabase) Lamptypes table contains 67 rows
              08:18:04.6391062 -- (SQLiteFunctions.InitDatabase) SensorTypes table contains 17 rows
              08:18:04.6547336 -- (SQLiteFunctions.InitScenes) starting
              08:18:04.6547336 -- (SQLiteFunctions.InitScenes) ScenesInit: Connected to databaseata Source=C:\Program Files (x86)\HomeSeer HS3/Data/JowiHue/JowiHue.db;Version=3;Pooling=True;Max Pool Size=100;
              08:18:05.1078889 -- (SQLiteFunctions.InitScenes) Read scene from database:
              **************************** Object info HSPI_JowiHue.HueDataSet+MyScenesTableRow *****************************
              {"Name":"Demo Alert step 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}},"Rowfout":"","RowState":2,"Table":[{"Name":"Demo Alert step 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}}],"ItemArray":["Demo Alert step 1","Demo","3",null,{"1":{},"2":{}}],"Hasfouts":false}
              ************************* End Object info ***************************
              {"Name":"Demo Alert step 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}},"Rowfout":"","RowState":2,"Table":[{"Name":"Demo Alert step 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}},{"Name":"Demo Alert step 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}}],"ItemArray":["Demo Alert step 2","Demo","3",null,{"1":{},"2":{}}],"Hasfouts":false}
              {"Name":"Demo Roll Scene 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}},"Rowfout":"","RowState":2,"T able":[{"Name":"Demo Alert step 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}},{"Name":"Demo Alert step 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}},{"Name":"Demo Roll Scene 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}}],"ItemArray":["Demo Roll Scene 1","Demo","3",null,{"1":{},"2":{},"3":{},"4":{}}],"Hasfouts":false}
              {"Name":"Demo Roll Scene 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}},"Rowfout":"","RowState":2,"T able":[{"Name":"Demo Alert step 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}},{"Name":"Demo Alert step 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}},{"Name":"Demo Roll Scene 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}},{"Name":"Demo Roll Scene 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}}],"ItemArray":["Demo Roll Scene 2","Demo","3",null,{"1":{},"2":{},"3":{},"4":{}}],"Hasfouts":false}
              {"Name":"Demo Roll Scene 3","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}},"Rowfout":"","RowState":2,"T able":[{"Name":"Demo Alert step 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}},{"Name":"Demo Alert step 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}},{"Name":"Demo Roll Scene 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}},{"Name":"Demo Roll Scene 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}},{"Name":"Demo Roll Scene 3","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}}],"ItemArray":["Demo Roll Scene 3","Demo","3",null,{"1":{},"2":{},"3":{},"4":{}}],"Hasfouts":false}
              {"Name":"Demo Roll Scene 4","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}},"Rowfout":"","RowState":2,"T able":[{"Name":"Demo Alert step 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}},{"Name":"Demo Alert step 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{}}},{"Name":"Demo Roll Scene 1","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}},{"Name":"Demo Roll Scene 2","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}},{"Name":"Demo Roll Scene 3","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}},{"Name":"Demo Roll Scene 4","Group":"Demo","Version":"3","BridgeScene":null,"SceneSet ":{"1":{},"2":{},"3":{},"4":{}}}],"ItemArray":["Demo Roll Scene 4","Demo","3",null,{"1":{},"2":{},"3":{},"4":{}}],"Hasfouts":false}
              08:18:05.1078889 -- (SQLiteFunctions.InitScenes) Debug: GetScenes finished normally
              08:18:05.1235182 -- (SQLiteFunctions.GetAnimations) starting
              08:18:05.1235182 -- (SQLiteFunctions.GetAnimations) Animation Demo Alert got 2 sequences
              08:18:05.1235182 -- (SQLiteFunctions.GetAnimations) ----- uses scene Demo Alert step 1
              08:18:05.1235182 -- (SQLiteFunctions.GetAnimations) ----- uses scene Demo Alert step 2
              08:18:05.1235182 -- (SQLiteFunctions.GetAnimations) Animation Demo Color Roll got 8 sequences
              08:18:05.1235182 -- (SQLiteFunctions.GetAnimations) ----- uses scene Demo Roll Scene 1
              08:18:05.1235182 -- (SQLiteFunctions.GetAnimations) ----- uses scene Demo Roll Scene 2
              08:18:05.1235182 -- (SQLiteFunctions.GetAnimations) ----- uses scene Demo Roll Scene 3
              08:18:05.1235182 -- (SQLiteFunctions.GetAnimations) ----- uses scene Demo Roll Scene 4
              08:18:05.1391405 -- (SQLiteFunctions.GetAnimations) Debug: GetAnimations finished normal
              08:18:05.1391405 -- (HueTools.StartMainTimers) starting
              08:18:05.1391405 -- (HueTools.MainWatchTimer) Debug: Checking plugin health 22-12-2017 08:18:05
              08:18:05.1547659 -- (plugin.InitIO) InitIO:Plugin basic initialisation done
              08:18:05.1547659 -- (HueTools.InitPlugin) starting
              08:18:05.1547659 -- (HueTools.InitPlugin) Debug: InitPlugin: initial checks
              08:18:05.1547659 -- (MyBridges.Init) My bridges init
              08:18:05.1703927 -- (MyBridges.FindBridgesSelf) starting
              08:18:06.0923345 -- (MyBridges.FindBridgesSelf) Debug: Searching for Hue devices
              08:18:06.1392109 -- (MyBridges.FindBridgesSelf) FindBridgesSelf: Bridge device found, checking vanHemert
              08:18:06.1392109 -- (MyBridges.FindBridgesSelf) Bridge device not yet in datatable, checking and adding it
              08:18:06.1548363 -- (MyBridges.BridgeCheckIP) called for 192.168.1.109:80
              08:18:06.3267227 -- (MyBridges.BridgesFillByDevice) starting
              08:18:06.3267227 -- (MyBridges.BridgesFillByDevice) Bridge check IP address 192.168.1.109
              08:18:06.3267227 -- (MyBridges.BridgeCheckIP) called for 192.168.1.109:80
              08:18:06.3267227 -- (MyBridges.BridgesFillByDevice) Bridge starting vanHemert (001788FFFE66D4F1)
              08:18:06.3423488 -- (BaseCache.StartTimer) Starting cache vanHemert
              08:18:07.0767776 -- (Mylights.InitialLights) starting for 'vanHemert'
              08:18:07.0767776 -- (Mylights.AddLight) Adding light Hue color lamp 2
              08:18:07.0924011 -- (Mylights.AddLight) Added hue bridge light Hue color lamp 2 of type Extended color light
              08:18:07.0924011 -- (Mylights.AddLight) Adding light Hue color lamp 3
              08:18:07.0924011 -- (Mylights.AddLight) Added hue bridge light Hue color lamp 3 of type Extended color light
              08:18:07.0924011 -- (MyGroups..ctor) vanHemert dresden: False Philips:True
              08:18:07.0924011 -- (MyGroups.InitialGroups) starting for 'vanHemert'
              08:18:07.1080304 -- (MyGroups.AddGroup) hue Group Added: All Lights
              08:18:07.1080304 -- (MyGroups.AddGroup) hue Group Added: Woonkamer
              08:18:07.1080304 -- (MyRules..ctor) vanHemert dresden: False Philips:True
              08:18:07.1080304 -- (MyRules.InitialRules) Debug: starting for 'vanHemert'
              08:18:07.1080304 -- (MyRules.InitialRules) adding new rule to table from vanHemert
              08:18:07.1236545 -- (MyRules.InitialRules) adding new rule to table from vanHemert
              08:18:07.1392787 -- (MySensors.InititialSensors) starting for vanHemert
              08:18:07.1392787 -- (MySensors.InititialSensors) Added hue Sensor Daylight of type Daylight and ref 0
              08:18:07.1392787 -- (MySensors.InititialSensors) Added hue Sensor Hue dimmer switch 1 of type ZLLSwitch and ref 0
              08:18:07.1392787 -- (MySensors.InititialSensors) Added hue Sensor Dimmer Switch 2 SceneCycle of type CLIPGenericStatus and ref 0
              08:18:07.1392787 -- (MySensors.InititialSensors) Added hue Sensor Timer.companion of type CLIPGenericFlag and ref 0
              08:18:07.1549061 -- (MySensors.InitTaps) starting
              08:18:07.1549061 -- (MySensors.InitRemoteControl) starting
              08:18:07.1549061 -- (MySensors.InitRemoteControl) would love to add Hue dimmer switch 1 but need to wait for plugin to finish starting
              08:18:07.1549061 -- (MyBridgeScenes.InitialBridgeScenes) Debug: starting for 'vanHemert'
              08:18:07.3736688 -- (BaseCache.StartTimer) BridgeCache: started for vanHemert True
              08:18:07.3736688 -- (MyBridges.BridgesFillByDevice) Baseurl Bridge vanHemert has been set to http://192.168.1.109:80/api/-THIS IS WHERE THE API KEY WAS, REMOVED FRANCOIS_
              08:18:07.7955758 -- (MyBridges.FindBridgesSelf) * Connected to bridge vanHemert at 192.168.1.109:80
              08:18:07.8268267 -- (UPNP.Bridgescan) Debug: Start Scan for bridges 22-12-2017 08:18:07
              08:18:08.6393846 -- (HueTools.InitDevices) starting
              08:18:08.6393846 -- (HueTools.InitDevices) Debug: InitDevices: Searching for Hue devices
              08:18:08.7175157 -- (HueTools.InitDevices) Found sensor Hue dimmer switch 1 on ref 935
              08:18:08.7175157 -- (HueTools.InitDevices) Sensor namedkey:bridgeserial
              08:18:08.7175157 -- (HueTools.InitDevices) Sensor namedkey:id
              08:18:08.7175157 -- (HueTools.InitDevices) Sensor namedkey:uniqueid
              08:18:08.7175157 -- (HueTools.InitDevices) Sensor namedkey:version
              08:18:08.7487673 -- (HueTools.InitDevices) other subtype:bridgeserial
              08:18:08.7487673 -- (HueTools.InitDevices) other subtype:id
              08:18:08.7487673 -- (HueTools.InitDevices) other subtype:sensorbattery
              08:18:08.7487673 -- (HueTools.InitDevices) other subtype:uniqueid
              08:18:08.7487673 -- (HueTools.InitDevices) other subtype:version
              08:18:08.7800201 -- (HueTools.InitDevices) Battery sensor device reference = 936
              08:18:08.8425251 -- (HueTools.InitDevices) Updating lightrow Hue color lamp 2
              08:18:08.9675332 -- (HueTools.InitDevices) Updating lightrow Hue color lamp 3
              08:18:09.2956811 -- (HueTools.InitDevices) other subtype:updatedevice
              08:18:09.2956811 -- (HueTools.InitDevices) other subtype:version
              08:18:09.2956811 -- (HueTools.InitDevices) Update device reference = 970
              08:18:09.3113072 -- (HueTools.InitDevices) Debug: InitDevices: End Hue Device search
              08:18:09.3113072 -- (HueTools.InitPlugin) Debug: Starting Device checks
              08:18:09.3113072 -- (HueTools.InitPlugin) Debug: 1 registered bridge(s) found
              08:18:09.3113072 -- (HueTools.InitPlugin) Debug: Refreshing Bridge vanHemert
              08:18:09.3113072 -- (HueTools.RefreshDevices) starting for vanHemert
              08:18:09.3581848 -- (HueTools.RefreshDevices) Debug: RefreshDevices finished succesfully for bridge vanHemert
              08:18:09.3581848 -- (HueTools.CheckLampTypes) starting
              08:18:09.3738109 -- (HueTools.InitPlugin) ============================================================ ==================================
              08:18:09.3738109 -- (HueTools.InitPlugin) 2 lights connected to bridge 'vanHemert'
              08:18:09.3738109 -- (HueTools.InitPlugin) 2 Groups available on bridge 'vanHemert'
              08:18:09.3738109 -- (HueTools.InitPlugin) 1 Remote switch(s) found on bridge 'vanHemert' with 1 supporting HS device(s)
              08:18:09.3738109 -- (HueTools.InitPlugin) 1 Daylight sensor found on bridge 'vanHemert'
              08:18:09.3738109 -- (HueTools.InitPlugin) 1 Generic flag sensor found on bridge 'vanHemert'
              08:18:09.3738109 -- (HueTools.InitPlugin) 1 Generic status sensor found on bridge 'vanHemert'
              08:18:09.3894370 -- (HueTools.InitPlugin) Debug: Config Done InitOK=True
              08:18:09.3894370 -- (HueTools.MainWatchTimer) Plugin succesfully started
              08:18:10.5145148 -- (Mylights.InitialLights) starting for 'vanHemert'
              08:18:10.5613944 -- (MyGroups.InitialGroups) starting for 'vanHemert'
              08:18:10.5613944 -- (MySensors.InititialSensors) starting for vanHemert
              08:18:10.8426627 -- (MySensors.InitTaps) starting
              08:18:10.8426627 -- (MySensors.InitRemoteControl) starting
              08:18:10.8426627 -- (MySensors.InitRemoteControl) Found existing remote on ref 935 - Hue dimmer switch 1
              08:18:14.4991678 -- (Web_Maintenance.BuildSliderBridges) -B- Opening slider bridge for vanHemert
              08:18:14.5147939 -- (Web_Maintenance.BuildSliderLights) -C- Build slider lights for vanHemert lightrows found = 2
              08:18:14.5616721 -- (Web_Maintenance.BuildBridgeOverview) -A- Build slider bridges for vanHemert
              08:18:20.5933467 -- (Web_Maintenance.BuildSliderGroupDetail) Error: web Maintenance group:Object reference not set to an instance of an object.
              08:18:20.5933467 -- (Web_Maintenance.BuildSliderGroupDetail) System.NullReferenceException(0x80004003): Object reference not set to an instance of an object.
              at HSPI_JowiHue.Web_Maintenance.BuildSliderGroupDetail(MyGroups TableRow Grouprow, Boolean Rebuilding, Boolean Close)
              08:18:36.5319560 -- (BaseCache.CheckBridgeUpgrade) starting a check for updates
              08:18:36.5319560 -- (BridgeCommander.EnQueue) Queuing new command: type Bridge current queue size is 1 on 001788FFFE66D4F1
              08:18:36.5319560 -- (BridgeCommander.HandleCommandQueue) Dequeue command: type Bridge new queue size is 0 on 001788FFFE66D4F1
              08:18:36.5319560 -- (BridgeCommander.HandleCommandQueue) sending command http://192.168.1.109:80/api/-THIS IS WHERE THE API KEY WAS, REMOVED FRANCOIS_/config to 001788FFFE66D4F1
              08:18:36.5475853 -- (BridgeCommander.HandleCommandQueue) HandleCommandQueue took 2
              08:18:36.5632997 -- (BridgeApi.SendJsonCommand) SendJsonCommand: Sending command PUT 08:18:36
              08:18:36.5632997 -- (HueCache.CheckBridgeUpdate) starting
              08:18:36.5944629 -- (BridgeApi.SendJsonCommand) SendJsonCommand: http://192.168.1.109:80/api/-THIS IS WHERE THE API KEY WAS, REMOVED FRANCOIS_/config
              {"swupdate2":{"checkforupdate":true,"install":false}}
              08:18:36.6413373 -- (BridgeApi.SendRequest) PUT total took 47
              08:18:36.6413373 -- (BridgeApi.SendJsonCommand) Sendrequest total 74 Thread:0
              08:18:36.6413373 -- (BridgeApi.CheckJsonResult) [{"success":{"/config/swupdate2/checkforupdate":true}},{"success":{"/config/swupdate2/install":false}}]
              08:18:36.6413373 -- (BridgeApi.SendJsonCommand) 0
              08:18:36.6413373 -- (BridgeApi.SendJsonCommand) SendJsonCommand: ready Sending command PUT 22-12-2017 08:18:36
              08:18:37.8447594 -- (UPNP.UDPListener) 21 blocks found to process
              08:18:37.8447594 -- (UPNP.UDPListener) UPNP: Known Bridge found on IP 192.168.1.109
              08:18:38.0635170 -- (UPNP.Bridgescan) UPNP deCONZ []
              08:18:38.0635170 -- (UPNP.Bridgescan) Debug: End search for bridges
              08:19:23.8634941 -- (Web_Maintenance.BuildSliderBridgeScenes) Error: web Maintenance:Object reference not set to an instance of an object.
              08:19:23.8790120 -- (Web_Maintenance.BuildSliderBridgeScenes) System.NullReferenceException(0x80004003): Object reference not set to an instance of an object.
              at HSPI_JowiHue.Web_Maintenance.BuildSliderBridgeScenes(MyBridg esTableRow Bridgerow, Boolean Rebuilding, Boolean Close)
              08:19:50.0370829 -- (BaseCache.StopTimers) BridgeCache: stopped for vanHemert
              08:19:50.0370829 -- (plugin.ShutdownIO) JowiHue Plugin is stopped. Thanks for using it :-)
                Hi Wim,
                I was wondering if you had the time to look at the above debug log (or still chasing the chrismas turkey...)
                I have been playing around with the PI and found some additional things that might be related to the issues I reported earlier:
                • I have added a HUE Iris to the bridge and restarted the plugin. I noticed a device was created in HS3 but it looks different than the others. The HUE Color lamps (LCT015-3) are built on 4 devices (parent, HUE CT and SAT) while the Iris (LLC010-4) only has three devices (parent, HUE and SAT. Missing CT). Not sure if this is caused by the device type though.
                • After I added the IRIS I re-created the demo set under presets with all three lights selected. When testing the demo settings I noticed that all three lights (including Iris) respond to Colorful and Soft Colors but when using the Whites presets the IRIS is not included in any of the presets. Should this work or is this a limitation of the Iris? BTW I have tried re-creating the demo set and restarting the PI but the result is the same.
                • When I create a new scene that includes the IRIS with a brightness of 254 and a color temp of 6400K, the Color Lamps will respond but the IRIS does not.
                  Francois,
                  The Iris is not capable of uing the CT values, that is why this device is not included in colour temperture actions. Also the ct device is not created. You would see the same when using a white or CT only bulb, only the needed devices are created.
                  At this point the trace is not helping me to find the cause for all lights not expanding.
                  Somewhere next week I will publishe a new beta for the plugin, solving several issues and also adding new support for creating sensordevices, less device dependant. The last is not directly interesting for you, nor do I expect the all lights issue will be solved. But could I ask you to join that beta test and , once you installed the new beta, let me know, so I can send you another update on this beta to have extra info on the error?
                  Wim
                  -- Wim
                    Wim,
                    thanks for getting back to me and explaining why the Iris does not have a CT parameter. I was more or less expecting something like that.
                    More than happy to join the Beta and provide feedback, only thing that might be in the way is the license code (trial license with 17 days left). I am in the process of evaluating the PI and waiting for the issues to be resolved before I make a purchase decision.
                      Wim,
                      The problem seems to be resolved, this is what I tried:
                      1. Upgraded to the new beta --> no improvement
                      2. Deleted the PI and all related files in HS, install Beta PI --> no improvement
                      3. Factory reset Bridge, delete the PI and all related files in HS, install Beta PI, pair bridge --> now all groups are populated and previously reported problems are gone.
                      Seems that de factory reset for the bridge fixed the issues.
                      The beta introduced a new issue with respect to the Dim switch, I'll describe that in the Beta thread.
                      Thanks for working with me.
                      Francois
