Weird HSTouch Dimming Control
  • Weird HSTouch Dimming Control
    Hello!
    I have HSTouch and also running the JowiHue plugin. I am noticing some really bizarre behavior. Whenever I open a light I want to "dim", I get an insane list of numbers up to 254. (VERY Very Low WAF) The weird thing is, all zwave lights have an "elegant" sliding dimmer. Why not this one?
    Thanks ~Brandon
    Originally posted by hs309 View Post
    Hello!
    Thanks ~Brandon
    You can go to Plug-ins and down to the jowihue plugin and then configuration. Under standard settings check the first two boxes at the bottom and leave the third unchecked.
      Hs309,
      Did the answer of cowinger (thanks!!) help you enough?
      Wim
      -- Wim
