Stuck on "Getting Scenes"
  • Stuck on "Getting Scenes"
    Hello,
    I'm running JowiHue 2.0.1.7, and whenever I go into the "Scenes" tab, there is one group that won't expand. Instead it sticks on "getting scenes" with a spinning wheel.
    I've tried restarting the hub and the plugin with no luck. There no errors reported in the HS log that I can see.
    Any suggestions on this?
    Thanks!
    - Brian
    Update: There are also these errors in the log.
    The "Error: (Execute):Scenedetail" always occurs after a specific animation starts. I've reviewed the animation and there doesn't appear to be any problems with it (it works properly, and the lights referenced are valid).
    The "Error: (BuildSliderTabDetail)" seems to occur when trying to open the group.
    Jan-08 10:29:58 AM JowiHue Error: (BuildSliderTabDetail):creativity:Object reference not set to an instance of an object.
    Jan-08 10:29:52 AM JowiHue Error: (BuildSliderTabDetail):creativity:Object reference not set to an instance of an object.
    Jan-08 10:27:45 AM JowiHue Animation Driveway Color Roll Finished
    Jan-08 10:27:43 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
    Jan-08 10:27:42 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
    Jan-08 10:27:41 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
    Jan-08 10:27:40 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
    Jan-08 10:27:39 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
    Jan-08 10:27:38 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
    Jan-08 10:27:37 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
    Jan-08 10:27:37 AM JowiHue Start of animation Driveway Color Roll
    Jan-08 10:27:37 AM Event Event Trigger "Driveway Alert Driveway Trigger"
    belias,
    I think the quotes in the groupname for the scenes are causing the lockup on the scene page. A few weeks ago I solved an issue with quotes in the name of a scene... but it looks like the group name is having the same issue.
    too late to solve it in the next beta, whichis already sent to HST, will try to solve it in the final version....
    Wim
    PS, could you post an image of the animation for me to check?
    -- Wim
      Think I'm getting a similar issue on 2.0.2.8 with an underscore '_'.
        Confirmed.... wow that I missed that one LOL!
        Will be solved in the next release
        -- Wim
          No worries. Appreciate the quick response!
            Me again... Couple Hue automations stopped working, and it looks like it is due to Jowi not liking one of the scene's names now?
            JowiHue Error: (BuildSliderGroupScene)::creativity: Column 'Name' is constrained to be unique. Value 'Living Room OFF' is already present.
              Yes, that is a limitation. Each scene needs to have a unique name. After renaming it, it should work again. Maybe you need to restart the plugin as well.
              -- Wim
                Following, but I when I go to do that in the creativity section, then it is stuck on "getting Scenes" when I try and expand that group. Restarting the plugin didnt fix it unfortunately.
                  Ok understand. Could you send me your JowiHue.db file, so I could edit it directly to change it? You can find the database in your HS3 installation directory at \Data\JowiHue\JowiHue.db.
                  Please send the file to w dot vuyk at upcmail dot nl?
                  Wim
                  -- Wim
