JowiHue Actions -> Set Lights . . . to Off . . . turns them on.
  • JowiHue Actions -> Set Lights . . . to Off . . . turns them on.
    I'm having difficulty getting the JowiHue Actions to turn Philips Hue lights off. I have had to resort to HS3's "Control a Device" action, which works perfectly.
    I've attached images of the failing event configuration. Changing the preset to <no selection>, or any other choice, returns the same result.
    I've attached images of the failing event configuration. Changing the preset to <no selection="">, or any other choice, returns the same result.
    Since you are turning all lights off maybe you could simply do this.
    </no>
      </no>
      I wrote, " I have had to resort to HS3's "Control a Device" action, which works perfectly. "
      Did you miss that?
        Did you miss that?
        My Bad!! I will try to figure out a way to switch them off.
        EDIT: OK I had to configure it in the pic below to get a light to go off.
