Philips Hue updates state time even without a state change
  • Philips Hue updates state time even without a state change
    Hi Wim,
    How do I keep my Hue bulbs from updating a state change in HS3 even when there is no change. I would normally try to turn off polling, but can't find a polling section. And I have checked off the "Do not update" checkbox already.
    Jim
    Plugins:Z Wave 3.0.1.55, HS3 Pro 3.0.0.208, HS3Touch, HS3Touch IOS, Z-Net, SceneMaster, XBMC, Sonos, Media Controller, Envisalink (52 Virtual nodes), JowiHue, EasyTrigger, Liftmaster MyQ, BLBackup, BLLAN, BLRadar, Pushover
    Devices:Cooper RF9540, Cooper Scene, Yale Locks, Sonos, Phillips Hue and Lux, DSC, Somfy Blinds
    Jim,
    Can you explain which devices are updating without a change? Are you seeing the group devices change maybe? As these will change based on the members in that group. If all members of the group are on, the group device will be on also. Or if a color bulb in that group changes color, the color value for the group are changed also.
    Also, if your bulb is in a colorloop, the hue or/and sat device might change as will based on the color.
    Wim
    -- Wim
      Wim,
      It now hasn't happened in awhile. Maybe it was something I did. If I see it again, I'll re-visit this thread
      Jim
        It appears to have happened with these entries in log:
        Jan-20 4:45:03 AM JowiHue Recovering light DR South
        Jan-20 4:44:55 AM JowiHue Recovering light Office Back Right
        Jan-20 4:44:49 AM JowiHue Recovering light DR East
        Does it need to change state on recovery?
        Jim
          Jim,
          Recovery only is performed when a bulb becomes reachable again after the start of being unreachable. That by definition changes the state as the plugin then will sent the last know values again.
          Is this after putting power back on the bulbs? Or is the bulb unreachable as in lost signal to the bridge?
          Wim
          -- Wim
            The power didn't go out as far as I know. Last nights Jowi log:
            Jan-20 6:49:08 AM JowiHue Curent software version = 1711151408 Current API version = 1.22.0
            Jan-20 6:49:08 AM JowiHue The update affects the bridge Philips Bridge
            Jan-20 6:49:08 AM JowiHue An update is available for the Hue Bridge (Philips Bridge) -- . Use the configuration page to upgrade.
            Jan-20 5:49:08 AM JowiHue An update is available for the Hue Bridge (Philips Bridge) -- . Use the configuration page to upgrade.
            Jan-20 5:49:08 AM JowiHue The update affects the bridge Philips Bridge
            Jan-20 5:49:08 AM JowiHue Curent software version = 1711151408 Current API version = 1.22.0
            Jan-20 4:49:08 AM JowiHue Curent software version = 1711151408 Current API version = 1.22.0
            Jan-20 4:49:08 AM JowiHue The update affects the bridge Philips Bridge
            Jan-20 4:49:08 AM JowiHue An update is available for the Hue Bridge (Philips Bridge) -- . Use the configuration page to upgrade.
            Jan-20 4:46:17 AM JowiHue Recovering light Office Back Right
            Jan-20 4:46:09 AM JowiHue Recovering light Office Back Left
            Jan-20 4:44:37 AM JowiHue Recovering light DR West
            Jan-20 4:26:36 AM JowiHue Recovering light DR East
            Jan-20 4:22:06 AM JowiHue Recovering light DR South
            Jan-20 4:21:54 AM JowiHue Recovering light Office Back Right
            Jan-20 4:21:50 AM JowiHue Recovering light Office Back Left
            Jan-20 4:21:44 AM JowiHue Recovering light DR East
            Jan-20 4:21:34 AM JowiHue Recovering light DR West
            Jan-20 3:55:00 AM JowiHue Recovering light Office Back Left
            Jan-20 3:54:50 AM JowiHue Recovering light DR West
            Jan-20 3:54:46 AM JowiHue Recovering light DR North
            Jan-20 3:54:26 AM JowiHue Recovering light DR South
            Jan-20 3:54:06 AM JowiHue Recovering light Office Back Left
            Jan-20 3:53:04 AM JowiHue Recovering light Office Back Right
            Jan-20 3:52:46 AM JowiHue Recovering light DR North
            Jan-20 3:49:08 AM JowiHue The update affects the bridge Philips Bridge
            Jan-20 3:49:08 AM JowiHue Curent software version = 1711151408 Current API version = 1.22.0
            Jan-20 3:49:08 AM JowiHue An update is available for the Hue Bridge (Philips Bridge) -- . Use the configuration page to upgrade.
            Jan-20 2:49:08 AM JowiHue Curent software version = 1711151408 Current API version = 1.22.0
            Jan-20 2:49:08 AM JowiHue The update affects the bridge Philips Bridge
            Jan-20 2:49:08 AM JowiHue An update is available for the Hue Bridge (Philips Bridge) -- . Use the configuration page to upgrade.
            Jan-20 2:34:06 AM JowiHue Recovering light DR North
            Jan-20 2:16:13 AM JowiHue Recovering light DR North
            Jan-20 2:06:19 AM JowiHue Recovering light DR North
            Jan-20 1:49:08 AM JowiHue Curent software version = 1711151408 Current API version = 1.22.0
            Jan-20 1:49:08 AM JowiHue The update affects the bridge Philips Bridge
            Jan-20 1:49:08 AM JowiHue An update is available for the Hue Bridge (Philips Bridge) -- . Use the configuration page to upgrade.
            Jan-20 12:49:08 AM JowiHue The update affects the bridge Philips Bridge
            Jan-20 12:49:08 AM JowiHue Curent software version = 1711151408 Current API version = 1.22.0
            Jan-20 12:49:08 AM JowiHue An update is available for the Hue Bridge (Philips Bridge) -- . Use the configuration page to upgrade.
            Jan-19 11:49:08 PM JowiHue Curent software version = 1711151408 Current API version = 1.22.0
            Jan-19 11:49:08 PM JowiHue The update affects the bridge Philips Bridge
            Jan-19 11:49:08 PM JowiHue An update is available for the Hue Bridge (Philips Bridge) -- . Use the configuration page to upgrade.
            Jan-19 11:16:34 PM JowiHue Recovering light DR West
            Jim
              Also, is there a way to force an update on Philipps Hue? I have auto update enabled but it always shows update available. I click it and it hangs on this screen for hours!
              Jim
                Jim,
                As for the update, it is taking a long time. Philips is busy updating all their lights for the entertainment options that are coming. For me I had it running all night before it ended.
                The other issue, bulbs being unreachable on regular basis might also be in the way of finisning the update btw.
                If you do not need the lights to be recovered after being unreachable, just disable the recovery option in the properties/JowiHue tab of the device. Then the plugin will let the device stay as it was after becoming reachable.
                You might also want to look to the reasons behing the lights becoming unreachable? Is there interference in the neighbourhood of the bulbs or bridge? A wifi router, using a channel near the philips bridge channel, or the distance between bulbs more then 7 meters might cause issues there maybe?
                Wim
                -- Wim
