Moving lights from Hue to Raspbee fails
  • Moving lights from Hue to Raspbee fails
    Running plugin 2.0.1.8 on HS 3.0.0.318
    Started moving my lights from the Hue bridge to Rapbee last night, and immediately encountered a problem
    The Raspbee finds the light no problem, and includes it just fine (as explained here https://forums.homeseer.com/showpost...7&postcount=35).
    However, the light isn't moved in the plugin, and doesn't appear at all in HS until after a restart of the plugin. Also, the light is still found in the Hue app, but that might be as expected?
    See log below (last night I moved a light, restarted plugin, added another light and waited just in case the plugin needed more time - this morning I restarted the plugin again)
    jan-23 08.14.13
    JowiHue
    jan-23 08.14.13
    JowiHue
    Plugin succesfully started
    jan-23 08.14.13
    JowiHue
    22 Presets available for use in the JowiHue plugin
    jan-23 08.14.13
    JowiHue
    7 Local scenes available for use in the JowiHue plugin
    jan-23 08.14.13
    JowiHue
    2 Animations available for use in this plugin
    jan-23 08.14.13
    JowiHue
    Device of reporting bridge and light firmware updates is enabled
    jan-23 08.14.13
    JowiHue
    1 Remote switch(s) found on bridge 'RaspBee-GW' with 1 supporting HS device(s)
    jan-23 08.14.13
    JowiHue
    1 Motion sensor(s) found on bridge 'RaspBee-GW' with 1 supporting HS device(s)
    jan-23 08.14.13
    JowiHue
    -------------------------------------Plugin info ---------------------------------------------
    jan-23 08.14.13
    JowiHue
    -------------------------------------Bridge info ---------------------------------------------
    jan-23 08.14.13
    JowiHue
    5 lights connected to bridge 'RaspBee-GW'
    jan-23 08.14.13
    JowiHue
    6 Groups available on bridge 'RaspBee-GW'
    jan-23 08.14.13
    JowiHue
    Bridge RaspBee-GW is at version 2.4.99 of type deCONZ on a RaspBee
    jan-23 08.14.13
    JowiHue
    2 Lightlevel sensor(s) found on bridge 'Philips hue' with 2 supporting HS device(s)
    jan-23 08.14.13
    JowiHue
    1 Daylight sensor found on bridge 'Philips hue'
    jan-23 08.14.13
    JowiHue
    3 Generic status sensor found on bridge 'Philips hue'
    jan-23 08.14.13
    JowiHue
    jan-23 08.14.13
    JowiHue
    1 Remote switch(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
    jan-23 08.14.13
    JowiHue
    2 Motion sensor(s) found on bridge 'Philips hue' with 2 supporting HS device(s)
    jan-23 08.14.13
    JowiHue
    2 Temperature sensor(s) found on bridge 'Philips hue' with 2 supporting HS device(s)
    jan-23 08.14.13
    JowiHue
    Bridge Philips hue is at version 1711151408 of type BSB002
    jan-23 08.14.13
    JowiHue
    12 Groups available on bridge 'Philips hue'
    jan-23 08.14.13
    JowiHue
    jan-23 08.14.13
    JowiHue
    22 lights connected to bridge 'Philips hue'
    jan-23 08.14.13
    JowiHue
    jan-23 08.14.13
    JowiHue
    Devices added for new light H°yre oppe
    jan-23 08.14.04
    JowiHue
    * Connected to bridge Philips hue at x.x.x.x:x
    jan-23 08.14.04
    JowiHue
    * Connected to bridge RaspBee-GW at y.y.y.y:y
    jan-23 08.13.57
    JowiHue
    Refresh bridge RaspBee-GW set to 30 seconds after establishing direct connection
    jan-23 08.13.56
    JowiHue
    socket opened for RaspBee-GW on y.y.y.y:y
    jan-23 08.13.51
    JowiHue
    InitIO:Plugin basic initialisation done
    jan-23 08.13.50
    JowiHue
    Starting plugin JowiHue 2.0.1.8 on Windows
    jan-23 08.13.40
    JowiHue
    JowiHue Plugin is stopped. Thanks for using it :-)
    jan-23 08.13.40
    JowiHue
    disconnecting brige RaspBee-GW
    jan-23 08.11.12
    JowiHue
    Error: (InitialLights):Objektreferanse er ikke satt til en objektforekomst.
    jan-23 08.05.42
    JowiHue
    jan-23 08.00.12
    JowiHue
    jan-23 07.54.42
    JowiHue
    jan-23 07.49.12
    JowiHue
    jan-23 07.43.42
    JowiHue
    jan-23 07.38.12
    JowiHue
    jan-23 07.32.42
    JowiHue
    jan-23 07.27.12
    JowiHue
    jan-23 07.21.42
    JowiHue
    jan-23 07.16.12
    JowiHue
    jan-23 07.10.42
    JowiHue
    jan-23 07.05.12
    JowiHue
    jan-23 06.59.42
    JowiHue
    jan-23 06.54.12
    JowiHue
    jan-23 06.48.42
    JowiHue
    jan-23 06.43.11
    JowiHue
    jan-23 06.37.41
    JowiHue
    jan-23 06.32.11
    JowiHue
    jan-23 06.26.41
    JowiHue
    jan-23 06.21.11
    JowiHue
    jan-23 06.15.41
    JowiHue
    jan-23 06.10.11
    JowiHue
    jan-23 06.04.41
    JowiHue
    jan-23 05.59.11
    JowiHue
    jan-23 05.53.41
    JowiHue
    jan-23 05.48.11
    JowiHue
    jan-23 05.42.41
    JowiHue
    jan-23 05.37.11
    JowiHue
    jan-23 05.31.41
    JowiHue
    jan-23 05.26.11
    JowiHue
    jan-23 05.20.41
    JowiHue
    jan-23 05.15.10
    JowiHue
    jan-23 05.09.41
    JowiHue
    jan-23 05.04.10
    JowiHue
    jan-23 04.58.40
    JowiHue
    jan-23 04.53.10
    JowiHue
    jan-23 04.47.40
    JowiHue
    jan-23 04.42.10
    JowiHue
    jan-23 04.36.40
    JowiHue
    jan-23 04.31.10
    JowiHue
    jan-23 04.25.40
    JowiHue
    jan-23 04.20.10
    JowiHue
    jan-23 04.14.40
    JowiHue
    jan-23 04.09.10
    JowiHue
    jan-23 04.03.40
    JowiHue
    jan-23 03.58.10
    JowiHue
    jan-23 03.52.40
    JowiHue
    jan-23 03.47.09
    JowiHue
    jan-23 03.41.39
    JowiHue
    jan-23 03.36.09
    JowiHue
    jan-23 03.30.39
    JowiHue
    jan-23 03.25.09
    JowiHue
    jan-23 03.19.39
    JowiHue
    jan-23 03.14.09
    JowiHue
    jan-23 03.08.39
    JowiHue
    jan-23 03.03.09
    JowiHue
    jan-23 02.57.39
    JowiHue
    jan-23 02.52.09
    JowiHue
    jan-23 02.46.39
    JowiHue
    jan-23 02.41.09
    JowiHue
    jan-23 02.35.39
    JowiHue
    jan-23 02.30.09
    JowiHue
    jan-23 02.24.39
    JowiHue
    jan-23 02.19.08
    JowiHue
    jan-23 02.13.38
    JowiHue
    jan-23 02.08.08
    JowiHue
    jan-23 02.02.38
    JowiHue
    jan-23 01.57.08
    JowiHue
    jan-23 01.51.38
    JowiHue
    jan-23 01.46.08
    JowiHue
    jan-23 01.40.38
    JowiHue
    jan-23 01.35.08
    JowiHue
    jan-23 01.29.38
    JowiHue
    jan-23 01.24.08
    JowiHue
    jan-23 01.18.38
    JowiHue
    jan-23 01.13.08
    JowiHue
    jan-23 01.07.38
    JowiHue
    jan-23 01.02.08
    JowiHue
    jan-23 00.56.37
    JowiHue
    jan-23 00.51.07
    JowiHue
    jan-23 00.45.37
    JowiHue
    jan-23 00.40.07
    JowiHue
    jan-23 00.34.37
    JowiHue
    jan-23 00.29.07
    JowiHue
    jan-23 00.23.37
    JowiHue
    jan-23 00.18.07
    JowiHue
    jan-23 00.12.37
    JowiHue
    jan-23 00.07.07
    JowiHue
    jan-23 00.01.37
    JowiHue
    jan-22 23.56.07
    JowiHue
    jan-22 23.50.37
    JowiHue
    jan-22 23.45.07
    JowiHue
    jan-22 23.39.37
    JowiHue
    jan-22 23.34.07
    JowiHue
    jan-22 23.28.37
    JowiHue
    jan-22 23.23.07
    JowiHue
    jan-22 23.17.36
    JowiHue
    jan-22 23.12.06
    JowiHue
    jan-22 23.06.36
    JowiHue
    jan-22 23.01.06
    JowiHue
    jan-22 23.00.03
    JowiHue
    Error: (HandleWebQueue):Objektreferanse er ikke satt til en objektforekomst.
    jan-22 22.58.22
    JowiHue
    jan-22 22.58.19
    JowiHue
    jan-22 22.58.11
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    4 lights connected to bridge 'RaspBee-GW'
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    jan-22 22.49.51
    JowiHue
    Enabled Colour Temperature control for group Ute terrasse
    jan-22 22.49.50
    JowiHue
    Enabled Colour Temperature control for group All Lights RaspBee-GW
    jan-22 22.49.48
    JowiHue
    Devices added for new light Venstre oppe
    jan-22 22.49.42
    JowiHue
    jan-22 22.49.42
    JowiHue
    jan-22 22.49.36
    JowiHue
    jan-22 22.49.35
    JowiHue
    jan-22 22.49.30
    JowiHue
    jan-22 22.49.30
    JowiHue
    jan-22 22.49.23
    JowiHue
    jan-22 22.49.23
    JowiHue
    jan-22 22.47.51
    JowiHue
    Devices added for new group Ute terrasse
    jan-22 22.47.48
    JowiHue
    jan-22 22.44.55
    JowiHue
    jan-22 22.44.55
    JowiHue
    AddGroup: Error Kolonnen BridgeSerial tillater ikke nulls.
    jan-22 22.44.55
    JowiHue
    jan-22 22.44.47
    JowiHue
    Did you have both bridge and gateway active while adding the light to deCONZ? also the plugin has to be active while the move is taking place and lights should be moved one by one. Tested it here (with the beta though) and it worked as it should.
    At the end of the move the plugin should remove the light from the old bridge so it won't be bothered anymore. I wonder what went wrong for you?
    Sensors are still a bit tricky to move, but lights should be almost rock solid - unless Murphy is around the corner?
    Wim
    -- Wim
      Yes, everything was up and running. Moved two lights, one by one.
      I've restarted HS today, and will try to move another light tonight to see if I'm luckier this time.
        Nope, same story.
        The log shows this repeatedly:
        jan-23 20.53.32	 	JowiHue	Error: (HandleWebQueue):Objektreferanse er ikke satt til en objektforekomst.
        jan-23 20.53.31	 	JowiHue	Error: (InitialLights):Objektreferanse er ikke satt til en objektforekomst.
          Stopped and started the plugin, got this in the log:
          jan-23 21.10.06	 	JowiHue	Devices added for new light Venstre nede
          jan-23 21.10.04	 	JowiHue	Devices added for new light H°yre nede
          These are the two lights I moved tonight.
            Hate when this happens
            If you dare to, could you enable the detailed tracing and log to file when you move another light? This will create a detailed log as a file in the logs subdirectory (JowiHue.log). I hope this will reveal something of what is happening to you?
            Send the log file to my mail address, don't post it to the board? w dot vuyk at upcmail dot nl.
            Wim
            -- Wim
              Mail with log sent last night
                Did you get the mail with the log, and did it shed any light on the problem?
                  Yes I got your mail, but it did not help me yet as there are to many points that might cause the issue. I am waiting for the new beta to be published by HST, from there I will mail you how to get more details....
                  Wim
                  -- Wim
