Moving Hue V1 to ConBee
  • #16
    Originally posted by nunoary View Post
    It create a new light on the device list. Now i have two, the first linked to hue bridge that i can't control anymore, and the new one named "Light 1" witch i can control. So i thing that the move doesn't go well.
    When it works it should not create a new light. I have done this with multiple lights. But I did have trouble with a couple of the lights and ended up with new devices.
    Bill
    • #17
      Bill
      Agreed. I only suggested it because it was a device that was not controllable therefore it should be OK to delete it.
      • #18
        Thanks @cowinger and @bdickhaus
        Yes, it should not create a new light. Yes i know i can delete the previous light, but i'll have to change my events and hstouch project, for every light i try to move . cowinger, i must have not explain correctly, that device was working before with my hue bridge, when i made the reset it stop to work. Supposedly it should be moving to deconz.
        cowinger, thanks for explain me how to add the parameter. I never knew how to do it. I was thinking that deconz should start after hs3, because when i start deconz before i have several problems with hs3 mostly with z-wave, i have my z-wave usb on hs3 machine to.
        But now i think, that if i add the parameter it should work fine. Thanks
        Do you know why i can't touchlink the livingwhites (LWL001) with conbee?
        Nuno
        Edit: i have change to c:\Users\....\AppData\deCONZ\bin\deCONZ.exe --http-port=8090, but now the deconz app don't start and ask me "How do you want to open this file?"
        • #19
          nunoary,
          On your C:\ drive you have a directory called Users. Double click that and it will show some sub-directories. One of those sub-directories will lead you to the deCONZ directory where the deCONZ exe file is located.
          In my case it is C:\Users\Larry\AppData\deCONZ\bin\deCONZ.exe --http-port=93
          So in my case the "Larry" sub-directory is what I put in place of the .... Yours will have a different name. I could not fill in that part because I do not know what your particular sub-directory is called.
          Also you will use 8090 instead of my 93.
          Try it that way and it should work.
          • #20
            Originally posted by cowinger View Post
            nunoary,
            @cowinger you made me left in a good way, thanks for that . lol
            I understand in the first place, the problem is when i rename "deCONZ.exe" to "deCONZ.exe --http-port=8090", it not open because doesn't recognize the extension and open the windows box asking what program i want use to open it. Hope you understand now.
            Nuno
            • #21
              Nuno
              OK, next you need to check your path. It may be different than what I have. Start at C:\ and follow it back until you reach deCONZ dot exe. Write down this path and give us a look at it. Also give us a screen shot of that window if you can.
              • #22
                Ok,
                My path
                C:\Users\admin\AppData\Local\deCONZ\bin\deCONZ.exe --http-port=8090
                Attached image, that's what happen when try to run deCONZ.exe --http-port=8090
                Nuno
                • #23
                  Ok,
                  My path
                  Nuno
                  The path is good. Try selecting Internet Explorer and say OK.
                  • #24
                    Don't work either...
                    • #25
                      Using the entire C:\Users\admin\AppData\Local\deCONZ\bin\deCONZ.exe --http-port=8090 create a shortcut on your desktop and try opening it that way.
                      If that does not work try using the port number 93 instead of 8090. I use it and it works.
                      Just for grins can you take a snapshot showing the complete path for the deCONZ dot exe.
                      • #26
                        Still nothing. Trust me the path i give it's right, that's not the problem.
                        Edit: I found another way. As alternative to using --http-port=<port> the default port can be changed in the config.ini.
                        On Windows it should be located in C:\Users\<User>\AppData\Local\dresden-elektronik\deCONZ\config.ini
                        Now back on the old stuff, and try to add a ikea light that bought today.
                        • #27
                          On Windows it should be located in C:\Users\<user>\AppData\Local\dresden-elektronik\deCONZ\config.ini
                          Glad you got it to work. Still don't know why it didn't but there are always other ways of getting to the same result.
                          As far as Ikea goes I don't have those so I can't be of any help. Sorry I couldn't help with the other also.
                          </user></port>
                          • #28
                            Nuno,
                            Having the flu I missed this discussion yesterday. Trying to crawl back here now. The essence of the --http-port was not renaming the file but starting deCONZ with extra parameters.
                            As for not baing able to add certain bulbs from Philips, I believe that indeed some older version like Living Colors and such are not supported by deCONZ, because the living colors are not Zigbee 3 compatible, so they can only be recognised by Philips.
                            Ikea should just work oth of the box, eventually after a reset (switching 6 times on and off).
                            Which version of deCONZ are you running?
                            Wim
                            -- Wim
                            • #29
                              Hi Wim,
                              Thanks, and i hope you get better soon.
                              I'm running V2.05.15 of deconz. Yes, Ikea light and remote was easy.
                              The living colors A19 (LCT001, 1st generation) it's compatible, i include one in conbee and the plugin creates the light. It shouldn't create a new light, it should change the bridge of my existing light. Now i have to do some work with events and HSTouch . The plugin don't makes the move.
                              The ones that i can't include are the living whites (LWL001)
                              https://www.amazon.de/Philips-691653.../dp/B005ER7MX2
                              I don't want, but perhaps i have to stay with the Hue Bridge
                              Nuno
