zigby Sensors want to add to HS3
  • zigby Sensors want to add to HS3
    I have several Visonic MCT-320 SMA door sensors in the house.
    They are Zigbee H.A. 1.2 supported network.
    I also have both Philips Hue round and square Models.
    What plug-in or hardware would I need to add these type sensors to Homeseer?
    Devoir
    Some of us use the conbee usb stick. The Jowihue plugin. Download the deconz software here. Version 2.05.00
    https://www.dresden-elektronik.de/deconz/win/
      Devoir
      Devoir,
      It should be supported by the Rasbee or Conbee. The challenge is that as far I can find they are not yet mentioned for the deCONZ-REST API that is used on these devices. So the developers of the software might not have added them to the rest-api. This plugin will not yet support them if they are not known in the REST-API.
      The philips bridges will probably not support them before Philips updates the V2 ridge with Zigbee 3 compatibilty and even then I doubt they will support the sensors.
      You might need to push the deCONZ developers on their github site.
      Wim
      -- Wim
        Zigbee to Go
        Wim & Cowinger
        Many thanks for the direction I will take your advice
        Devoir
          ConBee away
          I ordered this ConBee and posted on the GitHub website to add the manufacturer Visonic sensors....
          Thanks for your support
          Devoir
            no takers on GitHub for the sensors
            Devoir
              Devoir,
              Sorry to hear that. Visonic is using a protocol that is not Zigbee compatible helas.
              Wim
              -- Wim
