Aqara wired wall switch (double)
  • Aqara wired wall switch (double)
    Hello,
    Good news. This switch, that was already recognized by deCONZ, is now seen into Jowihue :
    https://www.gearbest.com/alarm-systems/pp_610096.html
    Pressing (physically) the buttons gives :
    - left 1 time = 4002
    - left 2 times : nothing
    - left 3 times = 1002
    - right 1 time = 5002
    - right 2 times : nothing
    - right 3 times = 2002
    - both simultaneously = 3002
    As these are values manually entered, I've tried to set them from another device, but the HS EVENTS doens'nt show them yet.
    Anyway, it's cool.
    Michel
    Michel,
    Could you send me the details of the Properties/JowiHue tab, especially the json part on that tab? I would like to check if it could be added to the xml file as well. The plugin recognises a lot of devices already (purpose of this beta), but still feel the need to refine here
    Wim
    -- Wim
      Hello Wim,
      Do you mean this ?
      ZHASwitch
      **************************** Object info *****************************
      "ep": 2,
      "etag": "5ce7b493302cec6e062bd9b97d739499",
      "mode": 1,
      "state": {
      "daylight": null,
      "buttonevent": 3002,
      "status": null,
      "flag": null,
      "humidity": null,
      "temperature": null,
      "presence": null,
      "open": null,
      "lastupdated": "2018-02-20T10:42:21",
      "lightlevel": null,
      "dark": null,
      "lux": null,
      "pressure": null
      "config": {
      "long": null,
      "on": true,
      "alert": null,
      "battery": null,
      "configured": null,
      "duration": null,
      "lat": null,
      "ledindication": null,
      "pending": null,
      "reachable": true,
      "sensitivity": null,
      "sensitivitymax": null,
      "sunriseoffset": null,
      "sunsetoffset": null,
      "tholddark": null,
      "tholdoffset": null,
      "url": null,
      "usertest": null
      "name": "lumi.ctrl_neutral2",
      "type": "ZHASwitch",
      "modelid": "lumi.ctrl_neutral2",
      "productid": null,
      "manufacturername": "LUMI",
      "swversion": null,
      "uniqueid": "00:15:8d:00:01:f5:0f:a4-02-0006"
      ************************* End Object info ***************************
        Michel,
        That is the one. I have updated the xml with the new info. There is still a bit of ongoing discussion on the github about the values. I think they have changed it with the latest version of deCONZ, so I used the values I found there for it.
        I am planning to submit the new beta soon, so if you want to test it, make sure to have the latest bet of deCONZ as well. Press the refresh device values on the device properties/JowiHue tab after the tables have been updated.
        Thanks!
        Wim
        -- Wim
          Thank you Wim, I'll do that as soon as you edit the new Beta.
