Samsung SmartThings Arrival Sensor
  • Samsung SmartThings Arrival Sensor
    Does anyone know if the Samsung SmartThings Arrival Sensor can be used with DeConz or Jowihue?
    Steve
    Steve,
    Is that a motion sensor? Does this github post answer this maybe?
    Wim
    -- Wim
      Proximity sensor
      http://amzn.to/2Hxog7u
        owww.. ok. That would be nice if it works. But I do not see if this sensor uses Zigbee, As far I know smartthings is using mere then one protocol for their communication?
        Wim
        -- Wim
          It uses ZigBee but the device doesn't work very well according to most reviews.
          -Rupp
            I see mixed reviews, some say it is having a lot of battery drain, others say it is rock solid with hits.
            I know I would love to try... Cannot find it here in Europe yet.
            Found it!!.... but twice the price compared to US price *sigh*
            Wim
            -- Wim
              Wim
                Steve,
                I saw you can already see it on the deCONZ environment? Maybe post the images for the endpoints on the github. That helps them to add it to the rest api. If it signals like a presence sensor, it should just add itself to the plugin like a presence sensor...
                Wim
                -- Wim
                  Wim, I assume that is the window on the left hand side when you select the device.
                  Steve
                    Steve,
                    Not only that but also the endpoints. these show when you press the (hard to see) most right eye on the samsung device in deCONZ. I have attached a sample for this, this will open a lost of enabled end points.
                    With each endpoint with hig higher number then 0 selected, you can click the tab cluster info on the left, to show the details per cluster. They will want that also. Can be quite a few images...
                    Wim
                    -- Wim
