"Object reference not set to an instance of an object."
  • "Object reference not set to an instance of an object."
    Hi,
    I've got this error message :
    It's an Aqara multi-sensor.
    This issue doesn't seem to break anything in my whole system. The lonely thing is that I can't "Rebuild device values" like I did for other sensors, and then I can't see pressure level for this particular one.
    Would you have an idea about that ?
    Originally posted by Michelob View Post
    Hi,
    [ATTACH]67019[/ATTACH]
    Michel,
    It suggests there is an empty field in the sensor where I did not really expect that. I will check on that.. it is the weather sensor of aqara?
    Wim
    -- Wim
      I guess so : it's called lumi.weather and shows Temperature, Humidity and Pressure.
      But I'm not sure that fixing this should be done by your side, as I've got 7 other similar devices that don't show any issue... Maybe I should reset this device ?
          Michel,
          This one trace line does not really help yet here. Is this occurring on the main device or one of the subdevices?
          Wim
          -- Wim
