Changed decimal value from , to .
  • Changed decimal value from , to .
    I just changed this setting on a Windows 10 machine running HS3
    Start -> Control Panel -> Time and Language -> Formats -> Additional date, time & regional settings -> Region -> Change data, time, or number formats -> Additional settings -> Numbers -> Decimal Symbol changed from , to .
    I need this for the temperature values to become 19.5 instead of 19,5 since i cannot send 19,5 to an MQTT broker to get it in grafana succesfully
    But now it seems it broke the JowiHue database in some sort of way
    mrt-01 12:58:57	 	JowiHue	Error: (UpdateLight):Object reference not set to an instance of an object.
    mrt-01 12:58:51	 	JowiHue	Error: (UpdateLight):Object reference not set to an instance of an object.
    mrt-01 12:58:49	 	JowiHue	==============================================================================================
    mrt-01 12:58:49	 	JowiHue	-------------------------------------Bridge info ---------------------------------------------
    mrt-01 12:58:49	 	JowiHue	10 lights connected to bridge 'Meterkast'
    mrt-01 12:58:49	 	JowiHue	7 Groups available on bridge 'Meterkast'
    mrt-01 12:58:49	 	JowiHue	Bridge Meterkast is at version 01041302 of type BSB001
    mrt-01 12:58:49	 	JowiHue	-------------------------------------Plugin info ---------------------------------------------
    mrt-01 12:58:49	 	JowiHue	0 Presets available for use in the JowiHue plugin
    mrt-01 12:58:49	 	JowiHue	0 Local scenes available for use in the JowiHue plugin
    mrt-01 12:58:49	 	JowiHue	0 Animations available for use in this plugin
    mrt-01 12:58:49	 	JowiHue	Device of reporting bridge and light firmware updates is enabled
    mrt-01 12:58:49	 	JowiHue	Plugin succesfully started
    mrt-01 12:58:49	 	JowiHue	Error: (UpdateLampTypes):constraint failed column ModelID is not unique
    mrt-01 12:58:49	 	JowiHue	Warning: Unknown lighttype found:LWB004 Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)?
    mrt-01 12:58:49	 	JowiHue	Warning: Unknown lighttype found:TRADFRI bulb E14 WS opal 400lm Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)?
    mrt-01 12:58:49	 	JowiHue	Error: (Groupcheck): Error on grouprow All Lights : Object reference not set to an instance of an object.
    mrt-01 12:58:49	 	JowiHue	Error: (Groupcheck): Error on grouprow Woonkamer : Object reference not set to an instance of an object.
    mrt-01 12:58:49	 	JowiHue	Error: (Groupcheck): Error on grouprow Dylan : Object reference not set to an instance of an object.
    mrt-01 12:58:49	 	JowiHue	Error: (Groupcheck): Error on grouprow Elin : Object reference not set to an instance of an object.
    mrt-01 12:58:49	 	JowiHue	Error: (Groupcheck): Error on grouprow TV Kamer : Object reference not set to an instance of an object.
    mrt-01 12:58:49	 	JowiHue	Error: (Groupcheck): Error on grouprow Buro : Object reference not set to an instance of an object.
    mrt-01 12:58:49	 	JowiHue	Error: (Groupcheck): Error on grouprow Hektar : Object reference not set to an instance of an object.
    mrt-01 12:58:49	 	JowiHue	Warning: Unknown lighttype found:RB 162 Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)?
    mrt-01 12:58:49	 	JowiHue	Warning: Unknown lighttype found:TRADFRI bulb GU10 WS 400lm Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)?
    mrt-01 12:58:48	 	JowiHue	Error: (UpdateLampTypes):constraint failed column ModelID is not unique
    mrt-01 12:58:48	 	JowiHue	Warning: Unknown lighttype found:LWB006 Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)?
    mrt-01 12:58:48	 	JowiHue	Error: (UpdateLight):Object reference not set to an instance of an object.
    mrt-01 12:58:48	 	JowiHue	Error: (InitialLights):DataTable internal index is corrupted: '5'.
    mrt-01 12:58:48	 	JowiHue	Error: INITDevices: unknown related device found: Bridge update ref:795 with devicetype: Scene
    mrt-01 12:58:48	 	JowiHue	Upgrading devices to latest version 10
    mrt-01 12:58:47	 	JowiHue	* Connected to bridge Meterkast at 192.168.110.84:80
    mrt-01 12:58:40	 	JowiHue	InitIO:Plugin basic initialisation done
    mrt-01 12:58:40	 	JowiHue	Error: (InitDatabase):Input string was not in a correct format.Couldn't store <0,45> in StandbyPower Column. Expected type is Double.
    mrt-01 12:58:40	 	JowiHue	Error: (InitDatabase):error occured at table: LampTypes with statement select * from LampTypes
    mrt-01 12:58:40	 	JowiHue	Starting plugin JowiHue 2.0.1.6 on Windows
    mrt-01 12:58:31	 	JowiHue	JowiHue Plugin is stopped. Thanks for using it :-)
    Hi again,
    On the other thread, I explain that after changing back to DOT decimal notation, Jowihue issues disappeard (as expected) but my problem into Easy Trigger also vanished (as NOT expected).
    So, everything is fine, without having understood anything, which is quite confusing in a such a rational context.
    Anyway, wait and see.
      I do not know to much about the MQTT broker technics, but I guess there will be settings to tell the MQTT broker to convert the EU settings to other settings? Localisation is not something new?
      Wim
      -- Wim
