(updatesensors):start: the given key was not present in the dictionary
  • (updatesensors):start: the given key was not present in the dictionary
    Xian,
    Could you send me a trace of what is going on?
    • Set detailed trace and logging to file in the configuration page/trace options
    • Restart the plugin and let it run for say 15 minutes
    • Disable the detailed trace and logging to file in the configuration page
    • Send me the \logs\JowiHue.log file?
    Send the log to w dot vuyk at upcmail dot nl?
    Wim
    -- Wim
      Thanks, I have just sent you an email
        Thanks to the trace Xian send me I found that the action Xian did, updating the NWK id, causes sensors (maybe also lights) to change their ID as well. The plugin does not expect the sensor to change its id internal on a gateway.
        So this caused an issue here that I have to find. I am on it, but the solution takes time. In the mean time.. do not change the NWK id in deCONZ or know this can happen.
        Wim
        *edit* still working on this, it might be different then I expected...
        -- Wim
