StartScene scripting documentation
  • StartScene scripting documentation
    Hi,
    Looking over http://www.vuyk.info/hs/jowihue/scripting StartScene is listed as a command and used in one of the examples, but the actual documentation is missing from the page. Any chance you could update that?
    Cheers
    Bill
    I guess I removed it after adding the new scripting commands for randomizing. Will update it. If you want to use it, the only parameter is the name of the scene
    Wim
    -- Wim
      Thanks, figured it out. Looking at directly supporting JowiHue in the SceneMaster plugin (have the Hue scene be a virtual device you can control along with traditional HS devices).
      Best
      Bill
        Would it be possible to extend the StartScene command to take an optional parameter off 'off' and use that to turn all the bulbs described in a scene off?
