Error: Object reference not set to an instance of an object.
  • #16
    Gentzel,
    I assume you have the same issue I found then. There is an issue with one of the fields in the dataset of lights when the plugin starts with a light powered off. It does not repair this when the lights becomes available again.
    It will be solved in the next release (crossing fingers for this week).
    Wim
    -- Wim
    • #17
      Wim,
      This is an enhancement I am really looking forward to. My wife has a habit of unplugging one of the lamps which throws the plugin off. Hopefully, this will solve the issue.
      BTW: If I haven't said it before this is great plugin that really helps deliver the HA experience - so thanks for all your hard work.
      A
      • #18
        adeux,
        I seem to miss the enhancement you are asking for? The issue with the errors mentioned earlier should have been solved with the latest updat.
        Wim
        -- Wim
        • #19
          adeux,
          Wim
          The problem I was having was that the bridge maintenance page was blank below the warning text. In the HS log was this error message.
          However, I have resolved the issue by updating the bridge firmware outside HS using the Hue app.
          Thanks again for a great plug-in.
