hs.SaveVar "Jon00PH"
  • hs.SaveVar "Jon00PH"
    Hi John
    Well I was going to as if the Jon00PH var can be retrieved after use or does it disappear ?? Yet that will not work for me,,, Is there a way to retrieve the current status of a HUE bulb ?? Basically I want to see if bulb #2 is on, off or what color it is ?? I could manually set a variable to track it , I guess..
    dem5867,
    Sorry for my late answer on this. I do think you are asking this in the wrong forum? I guess you ment to ask this to Jon00 maybe? This is the forum for JowiHue plugin. Which catches the current hue values fine BTW.
    See https://forums.homeseer.com/showthread.php?t=158743 for Jon00's forum for this.
    Wim
    -- Wim
