Alexa / Google Home + DeConz Color support?
For those following this thread, Color control from Alexa is working now, with some help form HST (Thanks!)
In the next release, coming soon color control will work properly. With extra thanks to Aleksander!
Wim
Originally posted by MattLau View PostIn hs3 you can enable devices by cheking the case’’ voice enable’’
when you add a rgbw light you have like 3-4 new devices associated. The first one is the root. You have to anable the root of the rgwb devices by cheking the ‘’voice’’ option . If it is not clear i will post a picture tonight
Guest repliedIn hs3 you can enable devices by cheking the case’’ voice enable’’
Originally posted by MattLau View PostI think you have to enable to root for alexa ...not just the rgb node .
Guest repliedI think you have to enable to root for alexa ...not just the rgb node .
Any solution for this? I still can't get any colour support on hue or deconz gateway (hue RGB or IKEA RGB).
I know Alexa support colour control. Is it just a setting I'm missing enabling rgb bulbs tgrouth this plug-in?
Originally posted by w.vuyk View PostJeubanks,
Out of curiousity, did the color commands work for LIFX?
Wim
For the moment I'm just accepting that for certain things (Color bulb support) I have use direct Alexa/Google connection and not go through HS3. It's a shame.
Originally posted by jeubanks View PostI got my LIFX bulb today. I'll be playing with that tonight after work. See if I can get any color commands through the UltraLighting3 PI. If not I'm going to say it's not a PI issue but a HS/Alexa API issue???
Wim
Originally posted by cowinger View PostI have some lifx bulbs and they are quite bright. They are the older version with 1130 Lumens. They are just adj white. They work great with the UltraLighting3 plugin.
Originally posted by jeubanks View PostNext time I try to run a test I will do that. I only have the 2 color bulbs currently and they are my daughters so it's hard to get them for testing. I did do the normal on/off/dim testing and all of that worked fine.
I have a LIFX bulb on order but that won't help with this testing.
Originally posted by w.vuyk View PostI hope another test could chime in.
You can also try to enable detailed tracing in the config ( + log to file) and perform some voice commands for on/off as well as color. Then disable the trace again and send me the JowiHue.log file (from hs3 install directory\Logs).
The I can have a look if the color command reaches the plugin. The on/off command is for me to have a working comparison.
Send the file to w dot vuyk at upcmail dot nl?
Wim
Wim
The title should be updated to be Alexa OR Google Home. I just did a test with the RGBW light with Google Home and no color control with Google either.
Does Color Control just not work with any voice control?
Sorry I cannot help you out there still. I have updated the plugin as Rich announced the availability of the ControlUse "Color Control" as condition to have color control for Alexa in a plugin. I have added this and also prepared code for hexadecimal input on devices.
But cannot test it as the skill is still only for the US and also Alexa does not know a word in Dutch
I hope someone else can chime in or we have to find a way to see if mentioning colors reaches the plugin somehow where we can trace things?
Wim
If I could ever get these 2 bulbs to pair with my Hue bridge it wouldn't be a problem, but for whatever reason (probably their firmware) I have never been able to get them to pair with my Hue bridge. Oh well... they pair just fine with my Echo Plus.
